How Do I Get My MPH Up?
8. Why the hell are we doing numbers???
9. Want to go faster, get some mods.... Like tires, 12.5 @ 116 is horrible... What was your 60'?
116 is a fine trap for a cam only, stock weight car.
You might want to drop some weight, and see what happens.. and give us your 60's..
I am running 125mph traps @ 418 rwhp... losing weight helps alot. I should actually be in the 127-128 range next time out, dropped another 200+ lbs last month....
What kind of what weight can i drop? i do not want my car to be a race car.
My 60' for yesterday was a 2.0 with my nitto 555 extremes (315/35/17) on my 17x10.5 TTMs
I was shfting jsut pass 6500 every time with the exception of crossing the traps. I crossed the traps in 3rd hitting ther limiter once at 7K
What does pulling the filter really do? I have done it before... And i think i need to droop my psi in my rears next time to 25 or 20. I had them down to 30 when they were HOT
i think the best option for you is skinnies up front and some drag rims in back that will save you around 100lb and give about 1.5mph...
What misc stuff could i with stand to lose?
I've always pulled the filter. Think of it this way, assuming you have a K&N, which is oiled. Try to breathe through a wet washcloth vs. no obstruction. See my point?
As far as tires, I think you're on 17's, look at the tire straight across at 30psi, do you think the contact patch will get larger at 20psi? I don't think it makes much difference if at all. However, since you do have the free time, why not take a straight edge to the car, and record the tire contact patch at the two pressures. I highly doubt there will be much of a difference, or enough to make the difference between a 2.0 60' and a 1.7 60'
Hatch flappy thing
Rear seat belts
Front sway bar - or at least disconnect it to aid in weight transfer
Miscellaneous crap in the car - loose change, floor mats, paperwork
Owners manuel
Anything else not bolted down
I FIRMLY believe that a lot of people would gain a .10 and 1mph by cleaning out their cars!!!!!!
A fresh 4 corner alignment may also help as well, ive personally seen a car pick up a half second with a good alignment, however it was in bad shape before the align.
Yes i am on 17s (315/35) You are prolly right that the contact patch will not get larger.. But anything can help right
