Drag Racing Tech
almost there: part 3
Old Jun 26, 2009 | 07:20 AM
White.Lightning's Avatar
Update???
Old Jun 26, 2009 | 08:38 AM
Randy WS6's Avatar
Id like to see some pics of the rear suspension and tub job. Very nice engine work, What color are you going to paint the car ?
Old Jun 26, 2009 | 10:49 PM
yrlosing's Avatar
Originally Posted by White.Lightning
Update???
still waiting on the fuel cell!! ordered a flat bottom one ( no sump) and still not here?
we are down to just wiring and cooling system. just hard to get going on it when it's 108 outside!!
Old Jun 26, 2009 | 10:55 PM
yrlosing's Avatar
i never took any with the rearend hanging in the car. these are the only chassis shots i have. sorry! was right after i painted it, so a little dark.
Attached Thumbnails almost there: part 3-100_0604.jpg   almost there: part 3-100_0665.jpg   almost there: part 3-100_0669.jpg
Old Jun 27, 2009 | 01:44 AM
allenwesley's Avatar
beautiful! i cant wait for my car to be at this point... good luck
Old Nov 1, 2009 | 08:26 PM
yrlosing's Avatar
finally done!!!
had a couple little setbacks
after getting it wired and running, we took a couple of road trips to see how it felt. on the second trip around the block and a good second gear run. it ripped a couple of teeth off the ring gear. so a new set was throw in and so far so good.
finally took it to the track sat night and did some shake down runs. firts pass out (motor only) 10.20 @140 this is where we found the front end problem! car pulled hard left and was fighting all the way down the track. found a loose suspension bolt, fixed it and made a second pass on a 100 shot.
8.90@154 can't wait to see what she does on the big kit!!
Old Nov 1, 2009 | 09:15 PM
RS_SS69's Avatar
Damn nice car man, did you get any vids of the passes?
Old Nov 2, 2009 | 07:56 PM
chvypwr31's Avatar
i forgot if i asked you before what size tire are you running, your tubs look smaller than mine.
Old Nov 2, 2009 | 09:29 PM
358chevycamaro's Avatar
I'd also like to know the tire size?
Do you have pics of when you stretched the quarters? How much did you remove??
Nice car btw, I should be starting on mine sometime soon except it will be Chromolly and 4-link...
Old Nov 3, 2009 | 10:08 AM
yrlosing's Avatar
no vid's sorry! i might get some this weekend if i have time?
always so busy getting the car ready i forget to shoot some!
Old Nov 3, 2009 | 10:10 AM
yrlosing's Avatar
33x10.5w
Old Nov 3, 2009 | 10:14 AM
  #32
yrlosing's Avatar
33x10.5w tires
i thought i had posted some pics of the side of the car? the wheelwell was moved 3.5 inches forward to make the tires look right
