Drag Racing Tech
I may be joining the darkside(m6 to Auto)
Old 06-29-2009, 11:55 AM
studderin's Avatar
noo!!!!!
its your, car so whatever makes you happy. I wish I had 4.56 or 4.88s, would be ideal. 4.30s on 28s 80mph is only like 2100rpms. I just put the LPE 2step, and my 275 DR was dead hooking @6K for a 1.61 and bogging. lol I need some more seat time, but its really easy. I dove the car like 200miles with weekend to a state park, same wheels. if you get 28 slicks, go to 28 street wheels too. I know the local "I just what to go fast" guys with 3sps can't really cruise around anymore there buzzing at 4K just to go 75mph. you know both sides of this deal
Old 06-29-2009, 12:11 PM
98blueSScamaro's Avatar
Originally Posted by patriotformula
sweet... I mainly go to Cordova... if you're ever around gimme a holler...
BTW if you do end up going with a th400 let me know. I have a local shop who is known for building 400s and he does it on the cheap! Built the one in my car and it works fantastic (<1000 with an electronic VSS built in and with a transbrake).
will do i may be heading out there soon always good track prep and clean track
Old 06-29-2009, 12:17 PM
Originally Posted by studderin
noo!!!!!
Yea for sure and with my 2step i am running into a dead hook and then a bog or a 6k burnout off the line buts it's from the tire i am running and the gears i am for sure looking at both sides but it is just really hard when your friends are on the cam only list with there autos and from a dig they put 3 cars on you Thats all and studderin have you been out with the new clutch yet???
Old 06-29-2009, 12:23 PM
studderin's Avatar
ya that one time. clutch dosnt slip at all so it boggs the motor if I dont spin. I just have to do fast slips,like I did last year on street tires when I was SI/ 340whp. I just kinda forgot about doing it, and just getting seat time using the 2step.
https://ls1tech.com/forums/eastern-m...7-nyi-fri.html
waiting to see the vids for some locals, I'll learn a lot more. but still think I should go 10's on the drag wheels. Car was 3360 with me now all back together last week.
Old 06-29-2009, 12:29 PM
patriotformula's Avatar
Ill be at Cordova this friday... Test and Tune then Midnight mayhem street race
Old 06-29-2009, 12:33 PM
Good deal for sure you are 110 pounds lighter then my junk with me in the car. I am on a fast slip as well. The 2step and dump = hook front wheels a foot off the ground then it just falls as fast as it went up and bog. but i will work with it some more
Old 06-29-2009, 12:54 PM
What is the midnight mayhem i have seen the add's for it is it good and can i get some money races off and alot of run's ????
Old 06-29-2009, 01:27 PM
Midnight mayhem is real hit or miss... one time you go up and you can get 6 or 7 runs in... another time you can get like 1 or 2 unless you make the fastest four at the end (shootout, but if you don't have a bottom 9 second car don't bother on that). The money races probably won't happen a ton because its normally a lot younger crowd. However, lots of good eye candy up there .
I plan on going up and running the test and tune that runs before Midnight Mayhem and then maybe making one or two runs in midnight mayhem. If I have a chance at the fastest four on bottle I'll give it a shot to say I made it.
Old 06-29-2009, 01:56 PM
what time is the test and tune start and end
Old 06-29-2009, 02:17 PM
6techniques's Avatar
another vote for auto here. I think the 400 is fine for dd duties as well.
Old 06-29-2009, 03:57 PM
Brian Coles's Avatar
Don't you know?? Every time a Fbody goes from M6 to auto an angle looses its wings.
Old 06-29-2009, 03:58 PM
  #32
BigKap94z's Avatar
DO it! I recently did the swap, and i have no regrets.
Old 06-29-2009, 05:52 PM
  #33
Tony 2000's Avatar
if interested in trading ive got a futral built turbo 350 with a 4k stall b&m bandit shifter, manual valve body, t-cooler, and cross member, reluctor wheel for speedo, Im located in ky, and tranny is still in car just wantin to go back to a m-6. and u should be able to keep ur chromoly drive shaft.
Old 06-30-2009, 07:02 PM
  #34
mike c.'s Avatar
Don't know what you got going but I 60 foot 1.42 n/a m6 car 26'' tire.
Old 06-30-2009, 08:15 PM
  #35
dreamls1's Avatar
I have been looking for a good trans shop to build me a th400, hook me up.
Old 07-01-2009, 06:11 PM
  #36
chrs1313's Avatar
...i had no part in this
i vote for OD...
Old 07-01-2009, 11:47 PM
  #37
Captain InsaneO's Avatar
After numerous hydraulic issues 4 clutches I was fed up and went A4 and I do not regret it at all. I even had a RPM stage 5 M6 with a textralia clutch and I am a pretty good driver with a manual car. I don't have to worry about miss shifts or inconsistant runs. I 60' better as well.
Old 07-02-2009, 12:08 AM
  #38
Wicked05Goat's Avatar
I would like to no when you think you are gonna do the swap?? As i am going to be doing the same to my WS6 going from a RPM Stage V Fully built to a Stage V 4L80E with a brake.. Would like to see how hard its gonna be i am doing mine very soon so i was just seeing when you plan on doing so.
Old 07-02-2009, 12:41 AM
  #39
99TransAmLS16Spd's Avatar
I am yet another on the verge of swapping -
Just recieved my LPE launch controller, so hopefully that helps. I love the instant torque you get from the M6 when at a roll, but launching is an art that I am beginning to think I will never master...
Old 07-02-2009, 12:49 AM
  #40
dochall22's Avatar
stay stick and learn to drive!
Quick Reply: I may be joining the darkside(m6 to Auto)
