Drag Racing Tech
WARNING LOTS OF PIC! 370 CI build
Old 08-12-2009 | 10:09 PM
  #61
StreetSilverado's Avatar
More updates comming Friday
Old 08-14-2009 | 12:30 AM
  #62
Got a couple of things done today but was pretty lazy after two weeks of working my *** off on customers cars (8am-10pm every day). Anyway, I'm picking up the heads tomorrow and I'm hoping to get the motor in the car and running by Sunday . It won't be driveable but maybe I can get a sound clip .
Here's a new addition to the shop equipment
New Cometic 4.030 head gaskets from TSP
Grandpa using the lathe to cut down the oil pump a little.
Also some grinding on the timing cover.
Here's how it ended up looking. It was a pain in the *** but finally got the Rollmaster double chain and Meilling oil pump to clear everything.
Old 08-14-2009 | 03:04 AM
  #63
bpowell688's Avatar
Lookin good blaine keep it up man, yall got it goin on now!! Im ready to get back home!!
Old 08-14-2009 | 09:53 AM
  #64
I went and picked up that Kent Moore line up kit from Marcus last night and I'm about to go meet the UPS guy here in town to pick up my valve seals so I can run them by Best Engines to get my heads finished up today and I'll be ready to put the whole motor together . Yeah I bet you are ready especially with them trying to blow you up !
I'll get some more pictures today...well...that's KaCee job
Old 08-15-2009 | 02:42 AM
  #65
Well the machine shop ran into some issues with using the springs but really no big deal. The parts will be there late Monday and I can pick up the heads Tuesday morning for sure. While all of that is being done I'll be getting the suspension and rear finished up. The shortblock is DONE .
Putting on the front cover with the Kent Moore line up tool
Putting in the front seal.
Instead of using the stock crank bolt we used a piece of hardened all-thread and doubled it on and loctited. Pretty much like a stud kit you can buy.
Putting on the rear cover and seal with the line up kit.
Here's what it looks like all done. Had to cut .125 on the crank pulley to make up for the timing chain spacers.
Old 08-15-2009 | 04:36 AM
  #66
bpowell688's Avatar
Hey can you have grandpa do the same thing to mine? I had no idea it was hitting!!
Looking good
Old 08-19-2009 | 02:43 AM
  #67
It's finally ready to go in! Just gotta round up a couple of fittings for the vacuum lines and stuff like that and in it goes! Here's what all went down Monday and today .
Pulled the K Member out and got it on the ground, also cleaned it up and painted it.
Everything else came out and it looks empty
Kinda experimiented with the valve covers and went with the new VHT wrinkle paint
Finally got the heads in today, and new valves. (Milled .025, New valves, and hand ported)
Time for the front Acc.'s
Then the intake goes on.
After everything is fitted on!
Time to get the PCM and everything hooked up and ready to do all the vacuum crap for the morning.
Well I hope I can get a small sound clip for you guys tomorrow
Old 08-19-2009 | 04:17 AM
  #68
bpowell688's Avatar
Hell yeah!! im exsited for ya!!!
Old 08-19-2009 | 04:46 AM
  #69
98Camarod's Avatar
looking good, when are you trying to have it down the track?
Old 08-19-2009 | 12:41 PM
  #70
Hope to have some track times in about two weeks if everything goes smooth.
Old 08-19-2009 | 07:39 PM
  #71
StreetStalkerZ's Avatar
Now it looks like your almost ready I hope to be ready about the same time you are,maybe i can tag along.
Old 08-20-2009 | 01:32 AM
  #72
SPEEDYws6's Avatar
I think we met at Red River? I had the black 6 speed TA.
Old 08-20-2009 | 01:45 AM
  #73
IT'S ALIVE! Finally after a hard day of finding the little parts for vacuum and etc. it runs. Well once we got it started up and added some water it had a really good water leak. We looked everywhere and came to the conclusion that the heads were screwed since it looked like it was comming from the very back passenger side head bolt. BUT when you look harder with a big light the plug was missing . I don't know how we missed it, I guess the machine shop took it out while working on the heads. Anyway got that fixed and out of the way and now just waiting on tomorrow morning .
So tomorrow the sub frames get built and welded in, transmission and all gets hooked up, torque arm mounted, LCA's and panhard, and everything else to get it rolling. Here's some more pictures and a video. I'll have to get a better sound of it later.
Got the motor all in and the PCM hooked up.
Had to replace the damn heater hoses and it's a pain in the *** while the motor and all is in the car
Here's when we found the water leak and got it fixed.
Now for the video...
Old 08-20-2009 | 01:52 AM
  #74
I've never had my camaro at redriver. I did race a yellow Jr. Dragster out there from 98' to 06 though. I also ran the dragster there once or twice. Whats your name?
Old 08-20-2009 | 02:36 AM
  #75
SPEEDYws6's Avatar
I must have you confused with somebody else. Everybody calls me by my last name Crow.
Anyway thats a good looking build you have there.
Old 08-23-2009 | 03:35 AM
  #76
Here is the car finally completed . Ol' daddy Greg will be giving it a tune tomorrow and off to the track I go next weekend .
I'll have to get better pictures and sounds tomorrow after the wash and tune.
Here's all the suspension done and rear end.
Put on the exhaust, it's running through a 18" bullet.
http://s391.photobucket.com/albums/o...t=100_0932.jpg
Here's the engine bay. It needs some cleaning but it runs for now.
Street/Strip form
Old 08-27-2009 | 11:12 AM
  #77
Here's some of the whole car. It's the only good ones I have for now
Old 08-27-2009 | 03:23 PM
  #78
That SOB is shinening like a diamond in a goats ***!
Old 08-29-2009 | 10:23 AM
  #79
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Looks great. Looking forward to the track times. Good luck.
Coach
Old 08-29-2009 | 12:23 PM
  #80
BennyB's Avatar
Very nice.
Quick Reply: WARNING LOTS OF PIC! 370 CI build
