Drag Racing Tech
Fastests built 346/347 ls1?
Old Jul 22, 2009 | 06:14 PM
  #41
BAKED's Avatar
Yup, high 5's should be good for LOW 9's. My car went 6.03 @ 114 on a 1.39 60' and went 9.36 @ 145 in the 1/4 on that pass. We have made a TON of changes to the car since then. Next time out should be interesting if everything works like it should....
Old Jul 22, 2009 | 06:23 PM
  #42
Rickys S/C Z28's Avatar
it will go fast! that what it will do
Old Jul 22, 2009 | 07:32 PM
  #43
chrs1313's Avatar
why the weak 60ft...still getting it dialed in
Old Jul 22, 2009 | 10:54 PM
  #44
a 1.39 is weak?
Old Jul 23, 2009 | 07:17 AM
  #45
chrs1313's Avatar
Originally Posted by Rickys S/C Z28
a 1.39 is weak?
for 145MPH, yes sir it is...
Old Jul 23, 2009 | 06:05 PM
  #46
kmracer's Avatar
should be more like 1.30, possibly better.
Old Jul 24, 2009 | 08:20 PM
  #47
BAKED's Avatar
The track wasn't too great. The best the car has cut is a 1.37 It might 60' a little better if it had a TH-400 in it but it would probably stand straight up. Right now it has a glide, 3.90 gears, around a 3200 stall, and 28" tall tires. I have a progressive controller on it now and I'm hitting it with a little more so it should do a little better.
How in the hell do you cut a 1.38 60' and only run 10.80's? Does it cut 1.3x's consistently? That's an awesome 60' for that ET and MPH.....
Old Jul 24, 2009 | 09:37 PM
  #48
chrs1313's Avatar
must be the converter difference...just have the basic suspension mods...and that was on a m/t drag radial 275/50/15 (26" tall) and foot braked...
it is usually low 1.40s it hit the 1.38 cause of real good track prep and the air was better so it make a hair more power...
made 3 runs
1.38
1.39
1.40
there are slips on yanks site
www.converter.cc
Chris
Old Jul 24, 2009 | 10:49 PM
  #49
BAKED's Avatar
That's some awesome 60's for the times you are running.
The glide don't help my 60's much either. On the 1.39 pass it picked up the front tires about 2 feet and carried them about 40 feet. That was off the foot brake also. If the track is there I'm gonna see how hard I can hit it off the line. I really need to get some decent front suspension in the near future. Mine is still completely stock right now.
Old Jul 24, 2009 | 11:16 PM
  #50
jmill96Z's Avatar
All you fast cars are getting crazy down there. I'm still trying to hit the rollers with a decent tune up here.
Old Jul 24, 2009 | 11:38 PM
  #51
BAKED's Avatar
By the looks and sound of your setup you are gonna be running just as fast if not faster!
I wouldn't do the whole tune up with it on the dyno, I'd get it somewhat close and then take it to the track to get it dialed in 100%. After it's finished then put it on the dyno. What kind of numbers has it made on motor?
Old Jul 24, 2009 | 11:58 PM
  #52
jmill96Z's Avatar
I think it made like 346 on motor Now I have some pro's working the tune. It was/is AFU. I'll get her hammered out though. Then I should start to see some times out of it.
Looks like we'll all be playing catch up to you though
Old Jul 25, 2009 | 09:02 AM
  #53
chrs1313's Avatar
holy hell 2 feet in the air is that 1.39 with the rear tires...
my car only lifts them like 5-6 inches...
this was the 1.39
http://www.youtube.com/user/chrs1313.../0/xKAo7FRk-Ro
Old Jul 25, 2009 | 04:22 PM
  #54
jmill96Z's Avatar
this was the 1.39
That's movin out pretty good.
