My slicks are shot should i run free 29/10.5/15
I will take some tomorrow after work. I pulled the wheels off so i can get you some pics to show you where it would rub. Then i will throw one back on to show you also. Thanks
There really isn't any room, I had to make room. Like i said i had to crank my LCA's so the tire went all the way back then shave a bit of the plastic back and mini sludge the metal back also. The front inside bottom of the wheel well is where the big problem was because you can only get it to move so much the frame is right there behind the sheet metal.
