Suspension Unloading At Launch..? (Vids)
Either way, get actual lowering springs as they are made to preform at that designed height, stick the stock ones back on or live with the bad 60's.
Mike
His definition of not getting traction doesn't match MY definition of not getting traction if you know what I mean.
Madman is on a whole other league than me. Wow, that low on tire pressure. That means I have lot's of room to work with then since I'm not running tubes either. I just didn't know how low I could get away with before it becomes a dangerous situation. Good info man, I appreciate it.
Mike
Obviously lowering is really hurting you, but you already know that.
For a "no dollars" test, i would go back out with the car with the front swaybar off, and the tires at 10lbs. Much lower than that and the car really does walk a lot on the big end, so i would definitely take it in small steps.
Just trying lowing the tire pressure and making the adjustments you had in mind on the instant center (never know... it may help more than im thinkin it will... my car wasn't lowered so i never messed with it that much)
Mike
Mike
Just a suggestion.
look at my vids from last week. blew the tires off then i went down two clicks on the front shocks.
I used to have revalved bilstiens on my car before. the only way i could make it hook was to run the rear very soft and like 11-12 psi
lowering the front of the arm will lift more weight and hit the tires softer. whats your rear LCA angle?
double adjustables on the rear is the best shock. even more than the front.
http://www.youtube.com/watch?v=drZHGYjuif0
http://www.youtube.com/watch?v=p5zM_TpNrk8
BMR LCA
BMR Adjustable torque arm
BMR panhard bar
BMR trans crossmember
BMR safety loop
BMR lowering springs
Energy Suspension mounts
UMI subframe connectors
GM 3.73 gear
PTC 4000 converter 2.4 STR
That is my suspension setup.. Race weight is 3550.. I cut consistent 1.52-1.54 short times on motor with 26" MT streets on a stock 8" camaro rim, dead hook... I want to lift the front wheels on the launch.. Is there anyway I could set the suspension up differently to make it lift the tires?
I am a suspension noob but have some buddies that know a little bit about it, no gurus though.. I know it will lift them on spray but I want to do it on motor first. I would be happy with both of them 8-12"..
Thanks for any advice..
here is a pic of my car with stock springs
m6 with 3.42 gears at 4500 rpm pulling 1.6s 60foot stock shocks and struts
its a 275/50/15MT DR with 17psi
stop being hard head and put some stock springs in. the higher a car sits the more LBS that gets transfered to the rear tires on take off
just do it !! LOL
my car does 7.22 @ 105 in the 1/8th on 17in rim and 1.8 60 foots how funny is that LOL
7.2@105.....
I would just like to bring them up just to do it.. No other reason.. Some might thinks its lame (dont think that could be considered rice material
Someone correct me if I'm wrong, but I was under the impression that you DON'T want the rear to squat. Weight transfer, yes, but not at the expense of having the rearend squat down. When the suspension squats in the rear, it's actually the axle pushing up away from the ground and unloading the tires. I thought the ideal situation is to have the tires being driven into the ground, actually raising the rear of the car, as long as the tire can hold it.
Mike
spohn anti roll bar. car setup was a stock bottom end ls1 w/ a 224/224, ported 243's and a 200 plate.
Chad
Correct. your problem is no weight transfer at all, and your shock setup is killing you. the cut rear springs are fine...friend of mine has gone best of 1.32's on cut rear springs. qa1's front/rear. madman torque arm, LCA's, PHB.
Chad
My next major purchase for the car is going to be some drag shocks for the front, even though I REALLY want a 2-step lol....Mike
I'm excited about this, but bummed at the same time. Excited to see what a dramatic difference a front shock can make, but bummed out because I won't be able to afford those until next season. There goes my chances for getting a 10sec timeslip this year.
I need to re-measure the LCA angle. It used to be 2 degrees but I haven't measured it since making the changes to the t/a. Pinion angle is now at -.5 using the driveshaft method.
Mike
