From 28x10.5/15S ET Drag to 325-50/16 ET Street Radial = Mistake?
CARTEK Racing
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Can I bolt up your 30's and see what happens? lol
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Of course you're welcome to them Alex.
You leave at 7k, the 30's aren't going to kill anything!
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Alex i would stay with the stiff wall slick ! ive tried the m/t dr 28in and the best i got was low 1.5's but things started to break no give at 5000-6500 lol
now your already in the low 1.4's so you would be taking a step back and a lot more frustrating getting it sorted out
its all about the suspension setup, like many guys have said the DR's will work but it takes time to get the setup right. RPM just did a 1.18 and smith did a 1.19 on 275's so a 325 should be a little easier.
maybe we could keep this constructive? ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
People aren't born knowing how to tune a suspension. How would you go about getting Alex's 6 speed car down the track on dr's? I'm interested and I'm sure Alex would be as well.
#33
Here is my set up.....01 ss 3786lbs with me in it..No weight reduction..All BMR except upper and lowers in front....Afco da on all corners...m6,viper converted...9'' 4.56's..LME 408 built in 06' 30k on motor..driven 250 miles a week...cuts 1.5 60' all day at local track...Car put down 531rwhp and 517rwtq before 9''.....Here is a video...Note, car has not been fully dialed in on the new suspension..Took it to Mad Man last year, and he worked his magick..Track prep was horrible and I kept blowing off the tires..1.62 was the best I could get....In this Vid, I cut a 1.43 and ran 8.77 in the 1000' (that's all we have) Launched at 5500 and no 2 step...I have alot left in the car..
Mine is the black ss in the left lane...Notice I miss 4th....
http://s189.photobucket.com/albums/z...009_220158.flv
#35
Most a4's can run almost the same settings as other a4 cars in their class if the cars are the same...I said ''most'' not all....
M6 cars are just violent on dr and need more supporting suspension work than a4 cars...
#36
CARTEK Racing
I have not made the mistake yet. I was considering it for the convenience. Brian himself suggested I use the stiff sidewall ET Drag but with all these guys running killer 60's with DR's I was thinking about it again.
I have always believed that the slick is better for a stick, I just wanted to see if other's agree, if not, I would try out a DR. I just did not want to buy $450 worth of tire w/o finding out if anyone had some luck with them on a stick car.
my car has every aftermarket suspention component except springs. B<R K-member and lower A-Arms, BMR SFC, 6 point roll bar to make the car stiffer, stealth torque arm, Sphon drag bar, QA1's on all 4 corners with stock springs, Madman PHB, BMR LCA's and so on...
Also like I said, i have been cutting 1.41-1.43 60's with my ET Drags, now I have the LPE launch control a few more ponies
lol and a bit more RPM lol I would like to see a 1.39 60', looks like I am most likely staying with the ET Drags.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#37
I agree bias-ply tires work better than radials for a manual transmission. I just want to observe that your best 60 was probably because your clutch was slipping. My two best 60s came just before clutch death. I'm on my fourth clutch. A new clutch may ruin your sixty, at least temporarily.
#38
CARTEK Racing
#39
Alex, its alot of fun driving to the track on DRs and racing, So why not do both. I thinks it a givin your not going to cut your 1.4s on them, but still run some good times.
But for your car to run both your canrun the taller DR, and keep the "go fast" setup 4.56s gears/28s ETdrags. I notice on my 28.00 DR I'd have to guess Im 2-300 rpms highter they the traps then my 28s etdrags, But I have room with the 4:30s not ideal for me traping 125ish
Whats out there for 29-29.5 tall DRs
What are you going to run with front tires with the DRs, becuse another thing in my DR setup is 4 stock chrome 16x8 rims, and a small 275 DR on the back, with stock sized 245 AVS1000 yocohams on the front. There 25.7 tall and weight alot (bare rims is 21#s). So thouse wheels add like 70-80lbs to my car over my gregweld/prostars. I think my 1.600 and low 1.6s is good for having stock wheels, if your gona get some light 15x10s and a light front tire setup I thing you could get it into the 1.5s consitatly with the 2step. maybe a low 1.5 once or somthing.
Best I've gone is some 11.2xs on DR 2 weeks ago.
#40
CARTEK Racing
Well, I was going to put the DR's on my 15" welds instead of my ET Drags... it would have been my "Go Fast" setup lol
Right now I have 27.xx M&H's on my stock WS6 wheels and that is my everyday setup. I have had them about 2-3 years so they are on their way out. I do have 2 TA chrome 16x8's that I could use for a ~28" DR setup, but once again that would leave me with bald *** M&Hs for daily use.
So right now, I think the best thing to do is buy a new set of 28" Drags because the ones I have are now nearly 2 years old and most likely shot to ****. And possibly get a set of ~28" M/T for my 17" WS6 wheels as a daily tire that I can also use for fun at the track.
