Drag Racing Tech
Trans Sheild
Old Sep 24, 2009 | 05:44 AM
chrismcdaniel's Avatar
Default Trans Sheild
Ok, i just got my Rossler th400 with a JW Ultrabell, but cant seem to find anything about a drum sheild that will fit the 4th gen tunnel without modification. anyone have something?
http://www.campbellenterprises.com/t...ionshields.php
http://www.tciauto.com/Products/Safety/
http://www.summitracing.com/parts/TCI-980005/
http://www.summitracing.com/parts/BMM-22151/
http://www.summitracing.com/parts/ATI-406610/
Old Sep 24, 2009 | 06:22 AM
BassProCamaro97's Avatar
A trans blanket is probably your only option unless you want to heavly modify the floor pan.
~Jim~
Old Sep 24, 2009 | 07:16 AM
veee8's Avatar
I use a blanket along with the ultrabell on my 400.
Old Sep 24, 2009 | 07:31 AM
veee8's Avatar
Old Sep 24, 2009 | 07:32 AM
thats what i asumed after looking at the available space, but i thought i would at least see if there was something.
Old Sep 24, 2009 | 09:11 AM
kp's Avatar
kp
A TCI will just make it if your fuel and brake lines arent in the stock location, plus you have to do some floor massaging with a BFH. But its super tight and not worth it IMO. I just use a blanket, I put the straps on the block on the LH side, back of head on the RH side so it doesnt slide back.
Couple pics, most guys dont use the straps going forward and without them its hard to keep the thing from sagging like a garbage bag.
Old Sep 24, 2009 | 09:35 AM
veee8's Avatar
Yeah I defiantly had to use the front straps. It was saggy without them, I really didn't want to see that thing come loose and get into the driveshaft!
Old Sep 24, 2009 | 10:53 AM
JL ws-6's Avatar
Race your car!
I have a CSR carbon fiber shield on my Th400..... covers the bell and the tranny drum. Not sure if it will work with an ultra bell or not, I assume it would though.
Old Sep 24, 2009 | 11:18 AM
I also run the CSR piece but I'm not sure about the specs on the Ultrabell so I can't say it would or would not fit.
The CSR piece is a combined shield (Flywheel/drum) and the ultra bell pretty much negates the real usefullness of the CSR. At $300 I'd think you'd probably be better off with the blanket.
~Jim~
Old Sep 24, 2009 | 11:21 AM
JL ws-6's Avatar
Race your car!
Honestly, I wish someone would just come out with a case for the Th400 like a dedenbear or ried case that are available for the powerglide.
Old Sep 24, 2009 | 11:30 AM
I hear that. You'd think with how many 400's are running out there something would be avaliable.
~Jim~
Old Sep 24, 2009 | 01:18 PM
veee8's Avatar
And maybe an ultra bell with LSX bolt pattern???????
Old Sep 24, 2009 | 07:56 PM
kp's Avatar
kp
I called and talked to them a couple years ago and they said there wasnt enough demand.
CSR shield wont work with an ultrabell unless you saw the front part off.
Sure would be nice if someone made a nice TH400 case with built in shields.
Old Sep 24, 2009 | 11:50 PM
team39763's Avatar
What do you guys mean a "LSX bolt pattern"? Doesn't the ultrabell bolt up to a LS motors the same as any regular Th350/400 bellhousing?
Old Sep 25, 2009 | 12:25 AM
kp's Avatar
kp
It bolts up, but an LS doesnt use one bolt on the RH side and uses one bolt in the center up high. It fits just fine but you can only use 5 out of 6 bolts. Not really a big deal, stock TH400/350/PG is the same way.
Old Sep 25, 2009 | 08:02 AM
team39763's Avatar
Oh I see.
Old Sep 25, 2009 | 08:26 AM
Yup, but there is some additional clearanceing that has to be done on the ultrabell that the stock bell doesnt require. Rossler charges a small fee to remove the side tabs and machine for the bolt clearance.
Old Sep 25, 2009 | 09:53 AM
tee-boy's Avatar
My ultrabell fit fine w/o any additional clearancing. Only thing needed clearance was the 4 bolts that hold the plate to the back of the motor.
Old Sep 25, 2009 | 11:48 AM
team39763's Avatar
The one I did was the same way...just grind for the 4 bolts.
Old Sep 25, 2009 | 01:14 PM
yup, that works, you can either grind the bolts, or clearance the bell. Rossler just offers to do it, for a small fee and the you dont have to worry about it. Works either way though.
