Who has used this Rear Sway Bar??
I have used this bar for 3 years and love it. Many low 1.40 60 foot times with a little ole 346 CI engine NA on a 26 inch tire. Front bar is off with adjustable shocks on back and front. I have not really had any problem driving around but I do not drive the car much anymore.
N2
N2
This car will have QA1's and for that reason UMI nis looking very attractive now. Thank you all for the input, this is extremely helpful.
R- series fronts and 12 way rears and lets say the UMI bar will be a good set up to compliment the BMR TQ arms, LCA and Pan hard rod.
The BMR is a little lighter (slightly smaller diameter and uses aluminum brackets and end link adjusters) and there isnt much of a price difference. The UMI looks good as well, I have an UMI K-member, A-Arms, rear arms and subframes on the new car, they make nice stuff.
Its a pretty simple device really and they all do the same thing so it boils down to price and if you care if clears the bigger shocks or not.
I happen to have all Spohn suspension and the product is a good piece! If I ever decide to spend the money to have a fast car I may upgrade to bigger shocks on the back and will buy a UMI drag bar at that time or an updated Spohn Bar!
N2
i have the UMI rear drag bar on my car & it's a very nice piece. i have a real light clunk coming from the rod ends, but also havent really adjusted it yet to preload it. i keep forgetting to call UMI & see how they set the adjustment, as i think i threw my instructions away when i opened it up.
Hope that helps!
Ryan
The original person that started this thread asked if anyone was using the bar and I gave my input but I forgot to say that my back shocks were Comp Engineering pieces. Sounds like he has gotten good advice from others as well and since he is going to use 12 way QA1's it sounds like he is going to need the room of the UMI bar! Just do not see any reason to talk down Spohn parts!
N2
N2
#32
I agree, why would you buy something that doesn't work with other aftermarket parts. It is pointless, the people that are buying these types of suspension pieces I am sure have other high dollar suspension pieces. I would not destroy a high dollar shock to get an anti rollbar on a rearend.
Far as Spohn goes they are a great manufacture for suspension pieces, I have had some on my car before, but if someone can make an anit rollbar that cleasr the shocks there is no reason why there piece should hit. Maybe there is some other reason spohn designed there bar this way? If there is it would be nice for someone to chime in.
#33
You asked how they work and I told you and I will say it again my best 60 foot to date is 1.39 with a 346 CI engine with no power adder on a 26 inch tire in a 3,370 lb car so I would say the bar does everything that Spohn said it would!! I do not feel that I wasted my money or that I purchased a part that is inferior. I would not state that the bar does not allow the use of bigger shocks and I do not know why anyone would buy one until they get the bar to work with bigger shocks!!
I am sure you will purchase the perfect part and have gotten good advice from most in this thread! The fact that the Spohn bar does not work with bigger shocks does not mean it does not work! The UMI and the BMR bars are very nice and Spohn does not sponsor me at all so I am sure any of the suppliers would love to have you business!
I hope this does not offend anyone but I am just stating the facts!
N2
#35
One question for you just out of curiosity why did you go with a BMR Drag Bar on your Firehawk and still just use Comp Engineering shocks when you could have used QA1's or AFCO's? This guy may want to know your thoughts about that!
Thanks,
N2
#36
No but I did pay a couple of salaries there a while back. I can read I know what folks are saying! Maybe a better way to have made your first statement was Spohn, BMR and UMI are all good products but if you plan to use anything other than stock shocks or Comp Engineering shocks you will need to look into buying either the BMR or UMI Drag Sway Bar! I am just giving you a little bit of a hard time. I think you can tell I am pleased with my Spohn drag bar!
Thanks,
N2
Thanks,
N2
I bought the BMR for this car for the same reason I bought the Spohn 4 years ago - it was on sale. Its not any kind of anti-spohn conspiracy
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#37
Whatever!
You forgot to answer the question about the shocks or do shocks not make a difference now as well!
I am DONE with this thread, no way to top that reply now we are talking about the color of driving suits! LOL!!
N2
N2
#38
If you really must know I used the CE shocks on this car because the first set I bought for my other car a while back were too long on extension (the recommended CE part number). I couldnt use them because the exhaust would hit the driveshaft when I let the rear hang down. I did the exhaust different on this car so I used them because they were here and it all cleared, plus they worked OK on the other car.
#39
I have the Spohn and have Hal adjustables and have no issue. It's close but it fits well.
I'm sure the BMR, UMI and Spohn all work very similar and you will get similar results with any of them. Bad think about the Spohn is the shock clearance issue and the fact that sometimes it won't fit a 12 bolt, it's a nice piece but like kp said, if there is going to be any kind of fitment issue and the others work just as well why bother with the Spohn?
Off topic, I just bought the Spohn pro series torque arm, it's MASSIVE!! Very nice piece.
#40
CARTEK Racing
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I have that bar as well. I have not had a chance to really launch the car with it, but on the street its not a problem. Car stays dead level even with the front bar removed.
I have QA1's in the back and got those little brackets that rotate the shock 90 degrees so the adjustmant **** is not neer the bar. Makes setting the shocks a lot easier and no fear of damage to the shock.
