Accufab 4150 TPS replacement.
I sent a couple e-mails asking about the vacuum ports on the body of the TB but never got any help from them. I wonder if they would help me with what car their TPS came from.
Since they sell them I am guessing I will not get any help there. Sucks because a new TPS from Advance was only $24.00.
http://chevythunder.com/fuel%20injec....%20pg%20B.htm
It seems I need a 1991 or later TBI sensor, not TPI.
Will report back this evening.......
My 100mm Accufab came with a Ford TPS and CARTEK had to modify the harness. Even then the TPS shows 4% when fully closed on tuning software. They had to solve that problem as well but at least the percentage would go up when depressing the throttle.
. Replaced the wires in the connector, took apart the TPS itself, no way to reverse the rotation. It is basically a spring loaded rheostat; if I reversed the rotation it would still start at 100% and go to 0%. It would just spring backward to 100%. Guess I head to Advance or Autozone tomorrow and see if they have on that rotates in the opposite direction. My 100mm Accufab came with a Ford TPS and CARTEK had to modify the harness. Even then the TPS shows 4% when fully closed on tuning software. They had to solve that problem as well but at least the percentage would go up when depressing the throttle.
The question I had about the vacuum ports was what size are the two small ones. I found the large center port was 1/8 NPT but never got an answer about the smaller ones. I was going to use a threaded plug but just used JB Weld instead.
Yeah, that is just stooopid.
