1/2" or 5/8" studs and billet specialties street lites...
Ditching the 31 spline trucrap for a 35 spline spooled setup in my 9", which studs do you recommend for my setup? Also what kinda stuff do I need to make them work with these wheels? I think i saw a picture awhile back with 5/8" studs and these wheels and it barely fits the opening in the wheel, not sure though. Also I'm assuming the 35 spline setup will be a remove/replace deal with my moser center section?
470ish rwhp + 300 shot
6 speed
3400 pound raceweight
4.11 gears
28x12.50 et streets
6 speed
4.11 gears
28x12.50 et streets
5/8 studs work fine, I think the early production ones the opening was a little small for the spacers to fit in and people had to turn down the spacers a bit.
You can just swap center (or spool only, they make a spool for the small bearing centers if thats what you have) and axles to 35 spline.
