Drag Racing Tech
Will the 12bolt live?
Old Oct 20, 2009 | 12:35 AM
Kevin97ss's Avatar
Default Will the 12bolt live?
Hey guys, couple questions. Will a spooled 33spline 12bolt with a 4.30 street gear live behind a TH400(2.75 1st) leaving off the transbrake, 4k stall, 3600lbs 360-400rwhp?
How many passes should I expect before I R&R the ring&pinion?
Is a 9in worth it at this point?
Old Oct 20, 2009 | 02:48 AM
35th SS's Avatar
your 1st and 2nd? I cant answer since I have no experience with a 12 bolt.but you know that saying do it once only.get a 9in. and never look back.
Old Oct 20, 2009 | 05:37 AM
96lt1m6's Avatar
you should not have problems with that 12 bolt....HP level really does not mean much since TQ is what breaks stuff.
Old Oct 20, 2009 | 06:36 AM
BlackScreaminMachine's Avatar
Internet Mechanic
That rear will live easily and be fine well into the 600-800 hp range.
Old Oct 20, 2009 | 06:55 AM
DannoWS6's Avatar
What he said
Old Oct 20, 2009 | 07:03 AM
JL ws-6's Avatar
Race your car!
Mine's lived at 9.50 for a season with no problems, 3.73 gear and a spool.
At your level it should be no problem, probably can go 3 years with nothing more then a yearly fluid change.
Old Oct 20, 2009 | 05:28 PM
Kevin97ss's Avatar
Sounds good,... reason I ask is the R&P in my current 12 bolt looks quite worn with somewhere around 30 passes and 2k miles, this was with the stick and current set up(see sig) launching off the 2 step. I figured I would freshen it up and sell it then build a new narrowed rear.
With serious bracket racing in mind I want it reliable so the 9in is also "on the table". Just trying to decide.
Old Oct 20, 2009 | 10:19 PM
Minshall's Avatar
Ive got around 60 to 70 passes on my 12 bolt. I leave off the foot brake around 3800. Not a single problem so far. The car cuts consistent 1.43 60ft times.
Old Oct 20, 2009 | 10:33 PM
Kevin97ss's Avatar
Is that with a street gear or pro gear?
Old Oct 20, 2009 | 10:40 PM
Kevin97ss's Avatar
Do you have any fitment issues with the 9in? Seems to be my biggest hang up besides the additional power loss. I dont want to any irreversable chassis mods, beating in the tunnel etc.
Old Oct 20, 2009 | 11:28 PM
35th SS's Avatar
no fitment issues here.most of my suspension are all adjustables.and no beating on the tunnel.
Old Oct 21, 2009 | 06:17 AM
JL ws-6's Avatar
Race your car!
Tq arm will probably put a dent in the tunnel, they have on every car I've seen to date, doesn't matter if you go 12 bolt, 9 inch, s60, they all generally need a little more clearnace.
not a big deal, you can't see it from inside the car. If you have the car lowered, it will be worse though, that I can tell you. As soon as I lowered mine, it re-clearanced itself after about 2 passes at the track
Not alot, but when I go under the car and nut/bolt it after every track trip, I can tell if the rear was set too soft if there's any additional mark Just part of putting a stronger/bigger rear in these cars, it's unavoidable for the most part.
Old Oct 21, 2009 | 04:54 PM
rm2500's Avatar
my 12 bolt has lasted five years now with no problem
Old Oct 21, 2009 | 05:12 PM
Kevin97ss's Avatar
Odd, my current moser has plenty of clearence with a prokit, though I'm still using the stock arm. JL, what part of the aftermarket arms hit on a 12 bolt? Could it be machined down or cut off?
Old Oct 21, 2009 | 05:55 PM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com...tCar.php?car=7
Check out the above Formula with a Moser 12 bolt and a Spohn torque arm, no clearance problems. Bob
Old Oct 21, 2009 | 07:25 PM
JL ws-6's Avatar
Race your car!
The bracket that attaches to the rear on my BMR tq arm hit.
I have the back of the car lowered about an inch, and depending on track conditions, I will sometimes have the shocks somewhat soft (some of these new england tracks and prep, aren't really friends, that and when it's cold out and there's no heat in the track sometimes ya have to soften the car up some to get it to hook).
It hit, when I had the rear shocks on 4, when I have had them on 5 to 8 the arm never really hit.
The mark it left isn't big, about 1/3 of a dollar bill if that makes sense.
Old Oct 21, 2009 | 08:03 PM
Kevin97ss's Avatar
Bob, thanks for that link!! There is a ton a great info there.
I am doing a different but similar build(NA,drag radial) for "street car" bracket racing and possibly an 11.50 index class. I intend to drive the car to the track (8 miles each way) and have it pass NJ state insp :o
Old Oct 21, 2009 | 08:15 PM
Kevin97ss's Avatar
Makes sence. So i'm guessing its the top mount plate that hits. That portion of the plate has the extra holes and overhangs, correct?
Are your jounce bumpers still intact?
Old Oct 21, 2009 | 08:24 PM
JL ws-6's Avatar
Race your car!
Yes it's the top portion of the bracket that hits.
I took the bumpstops off the car because I was having a problem with the car unloading when it hit them a couple years back, I never tried putting them back on, but I can't see that helping anything so I left them off.
It hit a little even when they were on fwiw, definitely hit more after then came off, at least for a couple passes anyway
Old Oct 21, 2009 | 09:50 PM
1BADAIR's Avatar
no hitting issues with my 12 and BMR ta here and the car over 1.5 lowered. you have to use the inner holes.
I have seen that 12 go 8's with no issues.
now, if it was a 6 speed you would have problems.
