Drag Racing Tech
stock studs on weld rims???
Old Oct 25, 2009 | 07:33 PM
01z's Avatar
01z
Exclamation stock studs on weld rims???
is it bad to run the stock studs w/ welds? right now i have 15x8 draglites and 5/16 spacer on the rear. will this be able to handle launches w/o breaking something? btw my car is a4 w/2.73 and stock stall with bolt ons. i havnt taken it to the track yet w/ this setup and it would be nice to know if im setting myself up for problems.
btw wasnt sure to post this here or in the wheel and tire section so if it needs to be moved go ahead
Old Oct 25, 2009 | 07:46 PM
Camaro396's Avatar
I've done it, but only for a short period of time until I got my ARP 12mm studs. I wouldn't recommend it. Just put the ARPs in it and sleep better.
Old Oct 25, 2009 | 07:53 PM
01z's Avatar
01z
im eventually going to get the correct studs. its just so tempting to take it to the track w/ these wheels cuz ive never had skinnies and DR's before. thanks for the quick reply
Old Oct 25, 2009 | 08:34 PM
CamaroRacing12's Avatar
if its a normal strict track they wont let u race. stock studs r not long enough if i recall correctly
Old Oct 25, 2009 | 08:50 PM
StreetSilverado's Avatar
+1 my stock ones weren't long enough. I would just go ARP anyway, they're only $30.
Old Oct 25, 2009 | 09:12 PM
Camaro396's Avatar
I missed the part about going to the track. Chances are they will tell you to get f'ed.
Old Oct 25, 2009 | 11:11 PM
dragracing91lx's Avatar
i run them with a spacer and ive been 1.53 60s no problems run them weekly actually...just re-torque them after each run after a few runs you will be ok, mine seems not to back off anymore after a few runs
Old Oct 25, 2009 | 11:18 PM
01z's Avatar
01z
no tech issues w/ stud length??
i could always roll up on my 16s and change em in the pits
Old Oct 26, 2009 | 02:50 PM
no i used closed long shank lug nuts
Old Oct 26, 2009 | 02:54 PM
BlackScreaminMachine's Avatar
Internet Mechanic
A proper tech guy will say it needs to protrude 1/4 of an inch (or half, as I do not have the book infront of me) past the lug nut.
Stock studs do not have the strength to handle the sheer and will either bend or break. Its borrowed time. Like said, its cheap to upgrade, I will be getting properly lengthed studs for my new rims, when they show up.
Old Oct 26, 2009 | 04:36 PM
kinda hard to protrude when I use closed lugs
Old Oct 26, 2009 | 04:54 PM
01z's Avatar
01z
anybody know the PN for longer replacement studs, i would still need to be able to put the stock rims on it too
Old Oct 27, 2009 | 10:45 AM
Internet Mechanic
You will have to look at the rule book as almost 98% of tracks follow, unfortunately individual choice can be the diff between caring and not caring about things like studs. There is a rule about needing metal valve stems and I think it is ET related but again. I gotta find my book.
Due to ease of inspections most if not all tech guys want to see the stud and not have the owner take off to show it has a longer stud, As some wheels may have all the threads, some are held on with 2 and 1/2 which happens and is dangerous and ultimately can lead to a costly breakage of your car and a waste of my time and other drivers.
Old Oct 27, 2009 | 08:30 PM
5.3LJimmy's Avatar
I ran the stockers for a while before I upgraded to ARP's with no problems. I doubt you will have an issue with a bolt on car, but you should upgrade them as soon as you can. You can use your stock lugs and wheels with the longer studs, but won't be able to use the plastic lug covers.
Old Oct 27, 2009 | 08:37 PM
i've had to remove lugs b4 i got my open ended lugnuts. apparently my track is just safer then other tracks.
Old Oct 27, 2009 | 10:12 PM
01z's Avatar
01z
well i will see how it goes as far as passing tech. i just want to get a few runs in. i will be ordering longer studs and not luanching it anymore until those are installed. thanks for the comments guys. here is the thread w/ pics of them on my car
https://ls1tech.com/forums/appearanc...draglites.html
Old Oct 28, 2009 | 03:17 PM
AChotrod's Avatar
Ive never been told I couldnt run because of the studs but I did get heckeled about my fronts not having SS screw in valves. Said if I went 11.99 or faster Id get the boot. Well I went faster and they didnt say anything.
