3rd Gen drag racing?
If i was looking to build a drag car I would look for one someone started with a cage or some suspensions mods as a roller because that will save you time and money. If you cant find that you can find them with blown motors or trannies in pretty much stock form for about 500.
exactly. stock motors are no good.
My problem is I dont like alot of cars I have done plenty of research for LQ/LS series motors and now I am nudging my way in the turbo scene I would really LOVe to find a firebird 98 and up that needs a motor and trans but people want a ridiculous amount of money for something that needs alot of work and time
http://philadelphia.craigslist.org/cto/1469028078.html
I'm partial to the birds
http://www.fquick.com/garages/viewga...wimg&id=253760
A lot of them out there for sale as rollers with work allready done.
P.S. I think the only thing difference in the rear department is the rear end is not the same width as the 4th gen rear.
Lots of info out there on BBC and LS swaps out there. LCA's, PHR, ect ect are the same as the 4th gen's.
By the time you get everything together to swap an LS motor into a 3rd gen, you are talking quite a bit of extra money and work. The cost use to work itself out, that is, a few years ago, it was fairly easy to find a very good condition RS for $3,000 or so but finding an LS1 4th gen for less than $10,000 was considerbly harder to do. But now, it's a different story - nice 3rd gens have held their value, while 4th gens racking up the miles can be had for a good price.
So I guess, from a $$ aspect, it really depends what all you would have done to a fourth gen anyways vs what you will do to the third gen. For example, I believe Hawks 3rd Gen is the only place that actually manufactures LT headers for an LS1 to fit in a 3rd gen and go for over $1000. And you will need a tubular k member with integrated LS1 motor mounts etc. But if you had already planned on going with an expensive header and tubular k member regardless of the car, the cost is the same. At that point it just comes down to the extras like the wiring harness, fuel tank and lines, etc.
As far as the origonal question - there are plenty of bad a$$ 3rd gen drag cars. Very similar to fourth gens suspension wise, with a little more room to work with under the hood
If you got a second or third gen (because you liked the looks better), I would swap in an LS platform of some type. I'd also recommend a 4L80 and 12bolt or 9inch rear.
Good luck
Good luck
