Who all is running 15x12's in the back?
didnt realize there was this shadow on the fender in the pic kindof hard to see the lip
With an 48" rear end what bs should I get? I'm thinking that 5"bs should work fine with the 315 tires...car was already started when I got it and the rearend, ladder bars and mini tubs all came with the car
I went with 15x12's with a 325 tire and it really seemed to stretch the side wall. even at 10 psi the side wall was real stiff. wish i would have went 15x10.
now i have hoisier 15x12x29 slicks and they fit nice. but i could not find a dr that fit well on this wide of rim.
#32
thats bull dookie. go on yellowbullet.com which i consider to be the biggest hardcore drag racing forum anywhere. and see what people are running. people are even putting the 315's on a 12'' rim
#33
hmmmmm
Jegs specs a M/T 325/50r15 drag radial @ a section width of 13.1" on a 10" wide rim. If you mounted this same tire on a 12" rim what would the new section width be?
Also would there be any negative side effects on traction by changing the shape or curve of the side wall as compared to the 10" rim? BTW this would be on a 3400# low 9 / high 8 second street car.
#34
the negative concern is the side wall becomes very stiff. and most all of the 325's rec a 10" rim width
Tire Size: P325/50R15
Tread Width: 11.75"
Diameter: 27.7"
Circle: 87.2"
Recommended Rim: 9-11"
Measured Rim: 10"
Section Width: 13.2"
Tire Weight: 29
Hoosier #522-17130QT
Hoosier Quick Time DOT Drag Tire
Tread: 10.5"
More Details
Share | $189.99
Ships
Today
$8.99
17130QT - Hoosier Quick Time DOT Drag Tires Details
10.5" Tread Width
Overall Tire Diameter: 27.8"
Average Roll Out/
Circumference: 87.5"
Tire Section Width: 13.1"
Required
Wheel Width: 8" to 10"
Tire Weight: 22 lbs
Note: Bold type indicates measuring rim.
the only ones i can find are the larger rims like the 315 in a 18" rim call for a wider rim. It did not work well for me is all i am saying.
Tread Width: 11.75"
Diameter: 27.7"
Circle: 87.2"
Measured Rim: 10"
Tire Weight: 29
Tread: 10.5"
More Details
Share | $189.99
Ships
Today
$8.99
10.5" Tread Width
Average Roll Out/
Required
Tire Weight: 22 lbs
