Drag Racing Tech
how to adjust phb
Old Jan 28, 2010 | 02:02 PM
TravisMcGill2000's Avatar
Default how to adjust phb
I tried doing a search and came up with nothing. Thanks for any help and advice
Old Jan 28, 2010 | 02:25 PM
tee-boy's Avatar
you turn the adjuster to ensure the tires are centered with respect to the chassis. (left to right)
Old Jan 28, 2010 | 03:01 PM
5.3LJimmy's Avatar
I place a straight edge vertically against the outside face of the tire and measure from the top inside edge of the straight edge to the inner fender on each side. Then adjust the PHB until they are equal. You must have the suspension loaded(car sitting on the ground or jackstands under the rear end) and make sure that you place the tape measure in the same place on both sides.
Old Jan 28, 2010 | 03:04 PM
AChotrod's Avatar
So do you.... do it on the ground with load on the tires? Jack the rear up? Can it be done on the car? If you adjust it off the car how the hell do you get it back in and lined up?
edit 5.3 answered alot of the questions in his post
Old Jan 28, 2010 | 03:39 PM
tee-boy's Avatar
you measure it with the rear loaded; you adjust it with the rear unloaded.
Old Jan 28, 2010 | 07:36 PM
any body got any pics doin it.
Old Jan 29, 2010 | 04:43 AM
Fb0dy0nly's Avatar
doin wha?
Sorry I just couldnt resist.
http://www.hotchkis.net/_uploaded_fi...513926file.pdf
really you just couldnt look that up?
Old Jan 29, 2010 | 04:50 AM
Fb0dy0nly's Avatar
you want more?....
http://www.go-fast.org/z28/suspension.html
I can do this all day...
http://www.gmhightechperformance.com.../photo_11.html
Old Jan 29, 2010 | 10:57 AM
thanks guys
Old Jan 29, 2010 | 12:27 PM
1CAMWNDR's Avatar
I am going to assume the inner wheel wells are the same distance on both sides from the finder lip? I know they sure are not flat. I think a straight edge on the face of the wheel and a measurement from wheel face to the fender lip would be better.
