My Extreme WEIGHT REDUCTION list & questions inside.....
12..ABS module
15..AC compressor
8.6.AC condenser
21..AC fan motor (entire assembly)
14..Airbag and bracket, passenger's
4...Airbag, driver's
.....Air dam
6...Air Pump (w/brass fittings)
3...Amp, Monsoon
4...Antenna, bracket, and motor if applicable
1...Ashtray & lighter
22..Bumper, front reinforcement and brackets
21..Bumper, rear reinforcement and brackets
41..Carpet & Sound deadening
15..Cats
8...CD Changer (stock)
10..Center console
.....Coating, under carpet
4...Crossmember brace
5...Cruise control (w/cable, throttle cable cover)
6...Dash brace (steel)
1...Door panel insulation
15..EGR, air pump, & harware
.....Emblems
5...Fenders (Inner metal)
7...Firewall Insulation
13..Firewall Insulation w/ plastic
3...Foglights and brackets
5...Gas Tank Evac Box
1...Grill insert
2...Hatch shocks
4.4.Head unit (Monsoon)
.....Head unit/AC console trim piece
8...Heat sheilding
9...Heater core (w/water)
8...Hood Latch w/ brackets
1...Hood shocks
3...Horn
45..HVAC, complete system
3...Inner fenderwells, plastic
2...Intake Silencer
.....License plate brackets
1...Lug Nuts (Chrome)
1...MAF
13e.Manifolds (stock)
.....Misc. junk in the car like keys, garage remote, change, etc.
1...Owner's manual
5...Panhard rod brace, upper
.....Parking brake
.....Power brake booster
5...Parking brake handle
.....Power seat motor
12..Power steering pump, pulley, idler pulley
17...Radio (stock in center panel)
9...Seatbelts (rears and passenger's)
7...Seatbelt (front only)
46..Seat, front (leather)
36..Seat, passenger (leather)
28..Seats, rear (leather)
4...Seat mounts and brackets (rear)
3...Sheetmetal, extra double walled
1...Shifter ****
20..Side impact bars (doors)
37..Spare tire and jack
.....Sail, Rear Speakers
5...Speakers (mid-base Monsoon, pair)
.....Spring isolators
2...Sun visors
14..Swaybar and brackets, front
1...Swaybar metal attachment
2...T-Top holders
11..T-Top hump/sheet metal
3...TCS motor
1...Washer fluid pump
8...Windshield washer fluid
3...Windshield wiper reservoir
4...Wiper arms
10..Wipers/motor
.....Wiring, Excess
.....Y-Pipe (w/2 cat.)
2...Y-Pipe hanger (stock, connected to tailshaft)
BUILD PLAN
.....A-Arms (PA Racing chromoly)
.....Airlid, K&N
19..Alternator relocation kit (PS removal, BMR)
13..Carpet (Spectra, lightweight)
38..Catback system (Slowmaster)
3...Chromoly LCAs
14..Chromoly A-arms
25..Chromoly K-member
17..Dry cell battery (stock location)
7...Electric water pump
.....Fuel cell
.....Headers, (forgive me) Shortys
20..K-Member (LS1 PA racing)
.....Lexan glass (Percy's speedglass front and rear)
15..Lightweight springs and shocks (Strange coilovers)
9...Lightweight steering wheel
10..Manual rack and pinion steering
15..Racing seat
18..Seat (Kirkey 17" prostreet/drag w/ cover)
6...Seatbelt (RJS 5-pt harness, camlock)
15..Shocks (Strange)
.....BBK Underdrive pulleys
56e.Wheels (Z06 18X9.5, 275/35 tire)
9...Y-Pipe, off-road
3.73 gears for the auto also
where are the "sheetmetal, extra double walled" and the "under car tow points?"
if those can be removed, id really appreciate info or answers to my questions
im shooting to at least break into the 11's stock internal
-thx in advance guys
Daniel
just a challenge to myself to see how fast i can make a stock internal LS1 go naturally aspirated on street brakes
im getting another SS with a whole different build plan. no weight reduction, internals and nitrous
i guess they should have added a 3rd section to the weight reduction list:
*free mods
*wallet mods
******* you shouldn't remove or your car is automatically a pile of crap
The 00' camaro is a lot more refined and went 11.03 at 3080 lbs. both of those stock internal.
but then again, id be happy as hell to even break 11's even with an 11.99
N/A also?
also, anyone have a rough estimate of what my car will weigh looking at my weight reduction list and build plan? car isnt finished or id go weigh it
keep in mind im running my stock brakes and stock rear
hopefully someone will say 2's
N/A also?
nobody knows what the extra double walled sheet metal is or where it is? or the under car tow points?
With help again this year from Shawn and Ed at Virginia Speed, as well as Hank Hill from hooked up and gone race car technology, should be a fun year going after that 10.68 record.
i think you'll hit it. good luck anyways. that is a great achievement and something to be proud of. id be proud of myself to hit 11s on SI and N/A. ive put alot of work into mine. i install all my boltons and weight reduce mine myself, so its alot of time and money invested but it always feels good to move up in the rankings
I think you'll reach your goal. Just remember, its not about what parts you use, its how it all works together. thats just a matter of going out there and trying things to see what works and what doesn't.
does nobody not know what the "sheetmetal, extra double walled" and the "under car tow points" is referring to? i just wanna know where this stuff is and if it can be removed
Maybe by double walled they mean things like the upper rad support bar?
The 00' SS we have is a SS with a few SLP factory options. I've cut the car all to pieces. I started with a very nice car, and when it's done, Its going to be a very nice car still. And worth way more then just the regular car it was before hand.
Its a 4th gen f-body. They made a ton of these cars. If you consider these collectable cars (short of bergers etc...) you've lost your mind. Hes not cutting up a 69 copo camaro. Let the guy do what he wants with his car.
thx for the compliment and support regardless
