Drag Racing Tech
My Extreme WEIGHT REDUCTION list & questions inside.....
Old 02-06-2010, 10:57 PM
  #41
MrElectric03's Avatar
Originally Posted by Ericbigmac83
^now if its a track car only i would have no problem with the mini tubs. cut it up
Ill probably end up doing it but that alot to cut out. Oh well may as well do it now while its stripped and easy to get around before the cage goes in.
Old 02-06-2010, 10:58 PM
  #42
nemss1's Avatar
a rollover. that's what
don't get me wrong, i've taken a hole saw to inconsequential places, but i couldn't cut out that whole section. Yea, i understand its not finished and cleaned up in those pics.
a rollover? that piece is thin gauge sheet metal mainly only meant to hold the qtr panel speakers. not support. the metal pieces behind the speaker panel metal (which are visible in my pic) are alot thicker and are actually meant for support. and of course, those are not coming out
Old 02-07-2010, 03:26 PM
  #43
nemss1's Avatar
anyone wanna help me remove my wipers/wiper motor? i tried the sticky but the pics wont display on my comp for some reason. pics would be helpful
the motor looks far back there and that is where im stumped
Old 02-07-2010, 03:58 PM
  #44
nemss1's Avatar
here are some pics from just a sec ago:
a view behind my dash. pretty empty
current interior pic
another straight-thru dash pic
removed airdam bracket
no bumper support, condensor, plastic or hood latch assembly
Old 03-29-2010, 06:59 PM
  #45
Empatho's Avatar
Is it easy to remove the Gas Tank Evac Box? and how is it done? I do not want to blow up my car
Old 03-30-2010, 02:16 PM
  #46
LadyDriven's Avatar
Ditto. Subscribing
Old 03-31-2010, 01:17 PM
  #47
STOCKTA's Avatar
For the fuel Evac system just unbolt the back driver's side wheel well and you will see the charcoal canister. Its hooked onto a sliding clip like peice of metal and you can tug up on the canister and it will come off. Then I removed the evap line under the car and followed it up to the plastic line to the Evap soleniod. I then removed the solenoid and used a ALLEN plug to put in place of the vacumm nipple where evap solenoid came off the intake.
I forget what it weighed I think about 7 lbs from solenoid/metal fuel line/canister. The breather hose that comes from the gas tank I zip tied a nitro methane RC car foam airfilter from the hobby shop as they withstand harsh fuel very well. You will smell a little gas if you fill the tank up all the way but if your like me I just ran a quarter tank allways for weight loss.
Im now using a 8 gallon aluminum fuel cell with a 250gph BG pump for a carb and plate kit so I no longer deal with any of this.
Old 03-31-2010, 02:32 PM
  #48
LadyDriven's Avatar
Thank you!!!
Old 03-31-2010, 11:07 PM
  #49
mike135531bubba's Avatar
You forgot to cut off one more bracket in this pic lol
any more pics?
Old 04-01-2010, 06:58 AM
  #50
suicidal racing's Avatar
yea, thats where i draw the line on weight reduction, don't think i could do that one
when i mini tub mine it will look like that..then ill trim the stock panels to work and put them back up..**** will look stock to the eyes..
Quick Reply: My Extreme WEIGHT REDUCTION list & questions inside.....
