lets see your custom air intakes
#44
Gonna try to come up with something a little different here in a couple of days.
I'm just curious, and I understand guys that are running the FTRA and "Chris1313" setup are still getting forced are but your trying to pull that air up from a vacuum? Has anyone cut out like say the license plate area and tried forcing air in that way?
I understand that "some" of the air will hit the bottom radiator dam thing and force it up, but like I stated your still trying to pull from vacuum. Wouldn't it get more forced air if you had it comming though the license plate area?
Maybe someone smarter will chime in...
#49
No it's a aluminum plate with duct connectors bolted into the holes with aluminum tape sealing the inside of the airbox. Aluminum tape is some bad **** it won't hardly come off.....been running it for years since i can't get the foam to stay put at high speeds. By far the best stuff i have tried for sealing the inside of the airbox.
#51
Mie comes off the 4150 throttle body carb hat into a 4" dryer duct (ghetto) that runs to the front of the radiator and turns down to the area right behind the license plate cover. Washer tank removed. Big K&N filter peeking out of the hole in the face. I have not bothered making a "box" for the filter; if I did it might have some Ram Air effect, but I am not worried about it. I'll try and get a couple pics tomorrow while I am changing my window motors.
