How to switch from keyed start to a switch?
Has anyone switched over to a button/switch start? How'd you bypass everything, and what about the chip in the key?
Seems like a good safety idea, incase of a problem, hit a button and the cars dead.
You can either do it with individual switches or with a box.
I've never done it with a modern car, but with old cars you can remove the safety
and the wheel will not lock when you remove the key.
As for starting & stopping, you rewire the key switch to two separate switches.
One switches spins the motor over, and one switch energizes the ignition system.
The safety from the key is bypassed, and the 2 new switches control everything except the locked steering wheel.
I've seen many many guys leave the key in and use their new switch box to actually control the car.
If I'm on the right track, I can help with everything except the steering wheel.
Now what wires do you cut/put a switch on I have no idea, I'm going to do this when I rewire my sled, but I'm ditching all the stock wiring, going with a BS3 and their engine harness, etc.
As I said, it is not complicated, the steering wheel locking in the middle of a pass is what must be taken care of.
You can control the starter with a remote ford style set up and push button, very easy.
The ignition, electronics and computer just needs an on off switch, which is also easy.
The only difference from car to car would be what each car has, stock, aftermarket, combination some of each.
Im personally going to use two toggles. One simple on off (For the IGN, on will turn the ignition and everything else on and when turned off it will cut the ignition and the motor). The other toggle will be an off/momentary on (meaning you need to hold it in the on position and when you let go it springs back to off, this will be for the starter only).
