In the marker for a car hauler, need inputs
- 2009 GMC Sierra 1500 SLE extended cab, 5.3L, Z60 suspension, 20in wheels, HD trailering pkg w/ 7-pin connector, Belltech 2/3 drop.
- 2002 Camaro SS, Straino lowering springs, Kooks headers (tuck pretty good), Kooks Y-pipe with cats (cats are the lowest point of the exhaust).
Here are some of the options I've been playing with:
Optimal length?
Type of floor (open/closed, wood/metal...)
Brake controller, do I need one?
Dove tail, tilting or something else
Removable fender?
What else should I be looking for? Any help would be appreciated.
16' deck 2' dovetail.) I plan on getting an 18' open wood deck with a dovetail, 3500# axles, and brakes on both axles. Reasons why I'm going with that setup is because my tow vehicle is a TBSS and I want to keep the trailer light as possible and I don't have the budget for aluminum. I chose wood because the trailer will sit outside in IL weather and it's easier to replace a wood deck than it is to fix a rusted steel deck. I chose a 16'+2' combo (18' total) because the car fits well and with our cars being so low a dovetail is a must. And last but not least I chose 3500# axles and electric brakes on both axles because again I want to keep the trailer light and I want the additional braking power just to be on the safe side. As for a brake controller I went with a Tekonsha P3. It's an awsome controller and it has an inertia activated sensor in it so it imediately sends a signal to the trailer brakes when it senses the truck slowing down. Sorry for being a little long winded, hope some of this info helps, and good luck with your search.
I measured my car, I have 9" clearance from the ground to the bottom of the doors. So I'll be loking for a trailer with fenders no more than 9" above the bed. Does a 18' trailer with a dovetail mean 16' + 2' dovetail industry wide or does it vary by manufacture? I'm seeing a lot of trailer that are 18' but it doesn't say how long the dovetail is. Also, is a 2" ball standard in this weight class or does that very as well?
