Drag Racing Tech
The Turbo Ta Build Thread
Old Jan 13, 2011 | 07:47 PM
  #121
Pillion88's Avatar
Yep one of my favorite build threads hope to get the goat back to byron some day
Old Jan 13, 2011 | 09:01 PM
  #122
Sideways240sx's Avatar
Originally Posted by bfurches
Chris, awesome build man...
I just read through the 6 pages of all the work you guys did, the car looks really mean.
Thank you very much.. Sean or myself will try to keep this thread going when we make changes.
Thanks, Chris
Old Jan 13, 2011 | 09:03 PM
  #123
bfurches's Avatar
Thanks, Chris
Do you guys plan on some more track time this season and turning it up?
Old Jan 13, 2011 | 09:37 PM
  #124
For sure. I dont want to jinx us.. but we shouldnt have any problems getting it out when the tracks open up here. When i was on the dyno i had fueling issues. I am running 2 walbro 255's, and a boost ref fuel reg. I had base pressure around 60(i think... its been a little while) it would raise to almost 70, then fall off to mid 40's. With the fuel pressure not keeping up my 60# injectors were maxed @ 9 psi... So we didn't push it.
Fueling issues should be takin care off. In the 9.8 pass we had 17% converter slip That is being fixed. We also were out of gear, so new one getting installed.
We will get a little more weight out of the car, i have the vfn lift off 5 inch slopped hood. Im trimming and mounting, then need paint. I also will probably be throwing a chute on the car.
(i am probably going to need it to pass tech or not get booted, since bryon is going nhra)
Thanks, Chris
Old Jan 13, 2011 | 10:11 PM
  #125
AChotrod's Avatar
Im coming for you guys this spring!!!
Old Jan 13, 2011 | 10:19 PM
  #126
Let me know when your going to the track. We will be ready
Old Jan 13, 2011 | 10:27 PM
  #127
AChotrod's Avatar
Motor is at the macine shop. I need me some single digits too.
Old Jan 14, 2011 | 12:46 PM
  #128
Broke EF's Avatar
Its about time! I have been trying to run you for years now!
As Chris said, thanks for the compliments guys. We haven't done much to it yet this year, but we are getting back into the swing of things. Updates should be coming soon.
Sean
Old Jan 15, 2011 | 08:36 AM
  #129
85IROCZmaro's Avatar
ye dude i just read all of this and this has got to be one of my favorite cars on this site
Old Jan 15, 2011 | 09:49 AM
  #130
Thank you!
Chris
Old Jan 15, 2011 | 10:22 AM
  #131
Taubr Unit's Avatar
im comin' for everyone!!
Old Jan 15, 2011 | 10:31 AM
  #132
Taubr Unit's Avatar
Congrats!!!Is this a 2 owner car or just 2 drivers?
haha funny you say that cause i was thinking the same damn thing!
Old Jan 15, 2011 | 10:54 AM
  #133
Broke EF's Avatar
BRING IT! We will be waiting at the top for you
It is a one owner, two builder/driver car. Unfortunately at this point in time I cant afford ****, so I dedicate my time to Chris's car to feed my car addiction. Lucky for me Chris likes building and modding cars as much as I do, and we generally are on the same page with how it should be done. So it works out well for both of us, he gets a lot of free help, and I get to work on something
Sean
Old Jan 15, 2011 | 12:04 PM
  #134
AChotrod's Avatar
Thats the way it should be^^ I help a lot of my friends when I got nothing to do to my car and they do the same for me.
Old Jan 15, 2011 | 12:35 PM
  #135
We have alot of fun building/ fabricating and just hangin out... beats going to the bar every weekend.
Old Jan 15, 2011 | 01:19 PM
  #136
Taubr Unit's Avatar
oh i heard that! Between all my buddys cars i have more time in theres then i do my own, lol. We just have rules...only the owner of the car gets to post pics of there car and we can comment on them, lol, doesnt look as weird
Old Jan 15, 2011 | 01:27 PM
  #137
sean is pretty big into photography, and he has more time then i do. If i was the only one posting there would be alot less pictures. I see how it can get confusing though. Chris
Old Jan 15, 2011 | 01:31 PM
  #138
Broke EF's Avatar
Well I post the pics, because I take most of them. Photography is one of my other hobbies, so I always have the camera ready. I guess the reason we both comment on it is because when if I see something and Chris hasn't addressed it yet I just will. It is a little confusing, but if/when anyone asks we explain it. One day I will have my own car again, and it will much easier to follow along
Sean
Old Jan 15, 2011 | 02:08 PM
  #139
Broke EF's Avatar
Well with all this resurgence in the TA, why not update while we are at it! We usually wait until after the holidays to really get after it and it was the same this year. We started last weekend but we weren't very motivated. The plan was to pull the trans to get the converter out. We got under the car and pulled the drive shaft, and took off the converter bolts. This gave us an opportunity to use the new BIG BOY ratchet!
Here is Chris getting it all set up
That is a Snap-On SLX-80, locking flex head, long handle 1/2 drive dual 80 ratchet. You can turn the motor so easy with it, its unreal! Having the right tool for the job makes it all so much easier.
Anyway he got the converter bolts off, and then started in the trans bolts. Once we started on the trans bolts, we both remembered the top bolt that is a pain in the ***. We actually installed it when the head was off of the car. That one bolt really unmotivated us, so we stopped on the trans. While Chris was under the car working I was up top pulling off the fenders. I actually pulled them off to get the back part of the hinges off of the car since it now has a lift off hood. Once Chris decided that he didn't want to pull the trans he started to lay out the fender supports to hole saw them.
And here is the results.
After that we gave it a quick coat of paint to stop rust, threw the fenders back on, and called it a day.
This weekend we actually tackled the trans, and got it pulled. Chris was able to get to that top bolt with the help of a long extension.
And here is the PTC converter that we are changing out. It needed to be re stalled, and after doing some research it was decided to go with a stronger unit. This converter worked great, but we are already at the limits of its power handling and we will be turning it up this year.
Thats actually about all we did. Chris started to run the second power wire for the fuel pumps, but that is nothing to look at. We should have more interesting updates in the next few weeks though. Here is how the car is sitting right now.
As always thanks for following along!
Sean
Old Jan 22, 2011 | 02:15 PM
  #140
GhostofKrypton's Avatar
Did you ever get a weight on your car?
