Drag Racing Tech
DOT approved Helmets?
Old May 3, 2010 | 03:13 PM
SpeedFreak123's Avatar
Default DOT approved Helmets?
In MD cars that run under 13.9, the driver needs to be wearing a DOT approved helmet. Anyone know of any sites to get one, or any places around MD to pick on up? I want to get it Powder coated with SOM paint, & maybe some flames or skulls, etc..
Old May 3, 2010 | 03:49 PM
358chevycamaro's Avatar
If you're looking for just a DOT approved helmet and not a SNELL approved helmet, Walmart sells full faced motorcycle helmets for $69 or $79.
Old May 3, 2010 | 04:43 PM
MetallicaMatt's Avatar
I agree, make sure you check if it has to be DOT and/or SNELL approved....
I would recommend going to a motorcycle shop and trying on helmets if your going to order one online - so you find the right size. My giant head needed a XXXL helmet.
Old May 3, 2010 | 04:51 PM
kenSS's Avatar
you will need a snell 2000 or newer to race. DOT means nothing in drag racing.
Old May 3, 2010 | 05:03 PM
greasemonkeysoldier's Avatar
http://www.helmetcity.com/index-nd.php
Old May 4, 2010 | 09:12 AM
Dirty Vegas's Avatar
www.newenough.com they usually have some good deals. I think that is where I got my RKT101 Carbon Fiber helmet.
Old May 6, 2010 | 02:50 AM
MJs1FastSS's Avatar
i recommend snell m2005 which is both DOT and SNELL approved so you ll be covered down the road if you decide to go faster.
HJC usually has 80-95 dollar base range that is both approved. for the money is the way to go esp if your going to spray it SOM.
HJC makes joe rocket 101
personally i am an arai corsair fan
as stated above go to a local shop and try a few on....each brand is going to be completely different fit and feel /pressure spots....order online and safe yourself the mark up
Old May 6, 2010 | 09:20 AM
HJC does make it, however the Rocket helmets are cast off a different mold. HJC is cast for skinny european guys, Rocket is cast for fat american heads.
Old May 6, 2010 | 02:59 PM
omcar's Avatar
EBay has a great selection..but you need to know your size. Get a Snell SA2005 if you can.
Old May 18, 2010 | 12:43 PM
green28's Avatar
Thanks for the link.
I think I might have to get one of those. I like the look and it's about in the price range I was looking to spend. Says it meets or exceeds SNELL M2005 & DOT which from what I gather would be NHRA legal, although the track I usually go to is not, but this way I'm covered if I visit one that follows those rules. Figure since my car is getting faster little by little it's time to get a helmet, plus I'm looking to buy an ATV so if I do get one it'll be nice to have for both.
Old May 18, 2010 | 01:13 PM
94Z28rag's Avatar
I'd never buy a helmet that cheap.
Old May 19, 2010 | 07:28 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
NHRA ules state the helmet is covered for 12 years from the date. Thus a Snell M or SA2000 would expire Jan 1st of 2012.
If you are planning for single digits eventually, get a full face helmet. I wear one and it helps me to concentrate on the tree and blocks a tad bit more noise in my opinion.
Derek
Old May 19, 2010 | 08:09 PM
djfury05's Avatar
hopefully everybody who owns a DOT helmet is aware that no actual testing of the helmet is required to be DOT certified. If you want to protect your *** you had better get either a SNELL or ANSI (American National Standards Institute) certified helmet. These certifications actually require real-world testing first. Just FYI for everyone
Old May 19, 2010 | 08:23 PM
cookba's Avatar
im looking at helmets too. are there any recommended? I remember using a buddys open face at on T&T night and it was like the top of the helmet kept touching the roof, and im only 5'5".
Old May 19, 2010 | 08:30 PM
djfury05's Avatar
the only recommended helmet I can suggest is one that YOU like and that is SNELL and/or ANSI approved.. there are going to be a lot of variables with helmets.. go to your Local motorcycle dealer and try on some helmets.. that simple
Old May 19, 2010 | 08:39 PM
cookba's Avatar
ya but bike shops just have bike helmets. A friend recommended a Simpson Bandit 1200032 but those are $400. plus where can you try one on. He drag races a lot though.
Old May 19, 2010 | 09:57 PM
Wnts2Go10O's Avatar
its not a md thing its a sanctioning body thing.
Old May 20, 2010 | 07:09 AM
green28's Avatar
So what is the major differences between say a Snell M2005 and a Snell SA2005? I know they would both be good till 2017 and that one is motorcycles and the other cars, but they would both be legal under NHRA rules correct?
Old May 20, 2010 | 11:28 AM
7 Second Club
I'm giving a general overview on this as I don't have my NHRA rulebook in front of me.
Both the M2005 and SA2005 would be good until Jan 2017, but some classes require the higher safety rated SA versus the M (a dragster would be one example where a SA helmet would be required, whereas I'm pretty sure an M helmet will work in a door car down to 8.50 in the 1/4 mile).
Derek
Old May 20, 2010 | 02:09 PM
green28's Avatar
Thanks for the info, I won't ever be fast enough that I would require an SA then. I will probably stop by the local motorcycle shop and try some on and order a M2005 so that I'll be good for quite a few years.
