Drag Racing Tech
Thoughts on exhaust setup...
Old May 7, 2010 | 02:14 PM
spoonraker's Avatar
Default Thoughts on exhaust setup...
Well I have two requirements.
1. It needs to be good for 600-700 HP (planning for way in the future)
2. It needs to have a cutout so I can make it quiet when needed but loud and open when racing
I'd like to keep it simple and cheap so I was thinking this:
Long tubes into Y-pipe which merges the two 3'' collectors into a 4'' pipe, 4'' electric cutout right off the y-pipe, and then as big of a muffler as I can fit right off of the cutout that just dumps down.
Would this work? Is there going to be enough room to fit an effective muffler in the proposed location? What kind of muffler would you suggest? Keep in mind the muffler will serve ONLY for quieting the exhaust, I will never ever race without the cutout open so the muffler can be as restrictive as it needs to be.
Old May 7, 2010 | 02:57 PM
94Z28rag's Avatar
I'm running LPP 1 7/8" stepped headers and putting dual electric cutouts on the LPP y-pipe right at the collectors...this will allow me to essentially run open headers OR my nice 3" Hooker Aerochamber catback at the flick of a switch.
Old May 7, 2010 | 03:15 PM
spoonraker's Avatar
Yeah that probably works great, but dual-electric cutouts and a full catback exhaust isn't exactly cheap.
I'm proposing nothing but a big y-pipe, into a single electric cutout, into a muffler and nothing else. I don't want the exhaust to come out the back I want it all to just dump as soon as possible but with the ability to either be loud or quiet.
Old May 7, 2010 | 08:35 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Finding a 4" muffler that actually quiets the car, will be rather large & not typically fit under the car, unless it is behind the fuel tank.
Much easier to fit two 3" mufflers with turndowns, or run a full length 4" setup. A good 4" system will not hurt power at all... no need for a cutout.
Old May 7, 2010 | 11:15 PM
94Z28rag's Avatar
your idea will leave you compromising somewhere. it all depends on what's most important to you and your budget. you need to specify both.
Old May 8, 2010 | 12:44 AM
spoonraker's Avatar
Alright, lets just throw the budget out the window.
I want to have the ability to be quiet enough to not wake up the neighbors when I come home early in the morning, but also have the ability to have a 100% restriction free exhaust that can support 600 HP. If I gotta do dual cutouts so be it, how you would set that up?
Old May 8, 2010 | 01:19 AM
LS1Tuner_06's Avatar
If so tHen you need a full exhaust. A dumped exhaus is goin to be loud and your neighbors will hate you trust me. Get a full exhaust and then get a cutout. A stainless manual QTP cutout is 50 bucks. You can get the electric switch later!
Old May 8, 2010 | 10:58 AM
MrElectric03's Avatar
Dumped exhaust will always be loud. If I were you id think about putting manual cutouts behind the headers and running a simple 3" catback. A Magnaflow system wont rob much power and wont add much weight. Maybe you could even mount a couple bullet mufflers and run the pipes back and have them removable.
My plan for my racecar involves cutting the rear seat pans out. Im going to run 3" pipes off the headers into an X and mounting two full magnaflow mufflers under the rear seat pans and dump it after that. It will be able to be removed quickly and im going to have a couple bullets to mount directly on the headers to race with at tracks that require more than a header muffler.
Old May 8, 2010 | 11:01 AM
94Z28rag's Avatar
Read back to my first post and do exactly what I'm doing. It is designed for 600 HP and to be quiet when needed. IF you have do make this setup from scratch it will probably cost $1500.
Old May 8, 2010 | 07:32 PM
spoonraker's Avatar
My car already has MAC mid tube headers and a hooker catback with a cutout after the y-pipe. That's how I bought it.
Even though it has a cutout, I was under the impression that a 3'' outlet y-pipe will rob a bit of power once I reach my power goals.
Maybe I should just take the existing cutout and move it to one of the collectors before the y-pipe, add another cutout on the other side, put in some new pipe where the old cutout was and be done with it.
Then I'd basically have the exact same setup you described, open headers when open, or a quiet enough hooker catback when closed.
Old May 8, 2010 | 08:19 PM
Factory or aftermarket Y?
Old May 9, 2010 | 01:11 AM
Wicked94Z's Avatar
I gained 10 rwhp with a cutout on my 4" single exhaust, and I'm not making 600 rwhp.
Old May 10, 2010 | 09:16 AM
spoonraker's Avatar
Pretty sure it's aftermarket.
Old May 10, 2010 | 06:54 PM
LS1TECH Sponsor
What muffler & what y-pipe were you running?
We did some testing on 800hp cars & gained virtually nothing power wise using the Mufflex with Flowmaster muffler. Y-pipe was the Mufflex dual 3" into a 4" collector.
Old May 11, 2010 | 06:26 AM
Wicked94Z's Avatar
3" y-pipe with flowmaster 4" merge, cutout at the rear axle, hooker max-flo muffler. Some mustang mag did a test on some 2 1/2" mufflers years back, the maxflo was the second highest flowing in the test I believe out of like 12 brands.
Old May 11, 2010 | 09:57 AM
spoonraker's Avatar
I'm not too concerned about the flow in the muffler. When I want power I'll just open the cutout and have a loud car. That's the whole point of a cutout isn't it?
I'm just looking for the cheapest way to put together an exhaust that will support 600 HP with the cutout open, but be somewhat civilized (quiet) when closed, even if it kills a bit of power. I won't be racing with the cutout closed.
