Drag Racing Tech
New cam only best!!
Old Jan 10, 2004 | 08:04 PM
StreetStalkerZ's Avatar
Thumbs up New cam only best!!
Well i got the new cam and TP 4400 in the car over the holidays and had the PCM retuned this week for the new TSP cam and headed to the track today to try them out. I had 3 things going against me right away with no miles on the PCM but the ones i put on the PCM going to the track,green track since it has been down for 3 weeks and the DA not as nice as last time i went (-1600/-1800). Today the DA was around -900 but still managed to run a new best on every pass today . My old best was 11.48@116.52 1.52 60ft. with the B1 cam and Yank Pro Stock 4400.
60 ft. 1.52
1/8 7.16@94.62
1/4 11.31@117.91
I ran 6 11.30s today with 2 118 mph passes with the best being 118.18. Im going to change up some things on the exhaust and try to go back later after they do several weekend runs to lay more rubber down. I was fighting traction on my last runs,which one of them was my best. I was only able to launch around 2500-2600 rpms and anything above that the tires would not hold and spin so i know there is more left in the car with better DA and a harder launch We will see in the next month how fast i can really go with the new TSP cam and PT 4400.
Old Jan 10, 2004 | 08:19 PM
CamaroCain's Avatar
Thumbs up
Sweet Watch out though, i may be coming after you soon Just with a different spec cam
I see you have 4.10's, is that in a 12-bolt or 10-bolt, do you think they help any, now with the big stall and the cam??
Old Jan 10, 2004 | 08:39 PM
MARKSZ71's Avatar
nice runs
Old Jan 10, 2004 | 09:30 PM
gator's 99TA's Avatar
very nice runs. i bet that 4400 and 4.10s work out well!
Old Jan 11, 2004 | 05:13 AM
Moose's Avatar
great times for a cam only car. Congrats.. car is really coming out of the hole..
Old Jan 11, 2004 | 06:31 AM
I think the 4.10s help more now with the new cam than with the B1 but the down side to 4.10s is that if the track is not semi prep'd you will spin. I think with 3.73s i can hook a little easier but i would be giving up a little topend in 3rd gear with the new cam. I was crossing all day at 6500 rpms so i was squeezing out every bit from this cam My shift extentions with the PT 4400 was 5800 rpms and it felt good to have a high shift extention converter back in the car,that helped out some over the Pro Stock i was running. I can't wait to go back in a few weeks because i really think with more learn time and a harder launch i can get 11.10s@119 out of the car the way it sets.
Lynda,slap the cam in and bring it on!!!
Scott
Old Jan 11, 2004 | 07:41 AM
Mike Hoffpauir's Avatar
Yeah Scott! Congratulations
Old Jan 11, 2004 | 09:46 AM
CamaroCain's Avatar
Scott
you forgot to answer one of my questions though...those 4.10's in a 10-bolt or 12-bolt rear??
Old Jan 11, 2004 | 10:33 AM
4.10s in a 10 bolt. This yank converters seem to be more forgiving on my 10 bolt than the Vig. and TCS converters. This is my 4th 10 bolt in the last year lol
Old Jan 11, 2004 | 03:11 PM
XFiveLiter's Avatar
Congrats! What was your race weight? That is some killer MPH. Good to see ya got the right converter in there now.
Old Jan 11, 2004 | 03:22 PM
DMcRacer's Avatar
Congrats on the new best man ! I guess its about time for me step it up a notch too. I cant have you and Lynda running off and leaving me
Old Jan 11, 2004 | 03:32 PM
XfiveLiter,my last check on raceweight was 3,390lbs but i think the scale was reading a little high that day with my usual being 3,365lbs. I think i can crack some 119 mphs with more practice and more weight removed because i have not got drastic on the strip mod yet,just the usual stuff.
DMcRacer,your car is impressive for bolt ons and should fly with a nice cam in it.
Old Jan 11, 2004 | 06:47 PM
Kent1's Avatar
Very nice and fast for a cam car. I hope one day mine will be the same. Good luck for the faster time.
Old Jan 11, 2004 | 10:38 PM
Frank95z's Avatar
Good job Scott. You've worked hard for it.Frank95z
Old Jan 11, 2004 | 10:45 PM
Jason99T/A's Avatar
I can shift faster than you.
Excellent times for a cam only setup! Good job Scott!
Old Jan 12, 2004 | 09:11 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Wink
Great times Scott!
Coach
Old Jan 12, 2004 | 08:03 PM
CamaroCain's Avatar
So far you are still kicking my *** I am hoping to see an 11.4 before I install the cam, but the way the car is doing I'm not sure that is going to happen just need to put the cam in and get some help on the big end.
Old Jan 13, 2004 | 04:16 PM
98TAauto's Avatar
son of aaaaaaaaaaaaaaa.. HAHAHHA congrats man!! Damnit, i wish my POS coulda 60'ed better on my 11.50 pass cam only way back yonder..
i have a feelin you are gonna go 11.1's once you get some more seat time in her now
Old Jan 13, 2004 | 05:26 PM
Roger White's Avatar
Nice times, thou I glad we didn't go. We almost loaded up for the track but at the last min didn't. Traction is a must with a PT..........
Old Jan 13, 2004 | 07:44 PM
Harold,thanks man The car seems to be running stronger on the low end now that im driving it more so im sure with more driving 11.10s will be mine Just that after that it may have to come down to getting carried away with gutting the car and spending some cash on off the wall things to get me in the 10s cam only IF the wife is not to pissed by then lol.
Roger,the track was hooking worse than it has since september and the PT's are unfogiven on the tires when the track is slick. I think on a good bracket day i can get a 1.4x out of it.
Mike Hoffpauir,any tips on getting into the 10s would be nice
