Battery Shut Off Switch, Does it need to be Visible for NHRA rules?
NO it does not have to be visible. They only need to know were to turn it off at. THE HANDLE MUST BE VISIBLE, not the switch itself. If you have a push/pull rod, PUSH MUST BE OFF.
2010 rulebook:
8:4 MASTER CUTOFF
Mandatory when battery is relocated, or as outlined in Class
Requirements. An electrical power cutoff switch (one only) must be
installed on the rearmost part of each vehicle and be easily
accessible from outside the car body. This cutoff switch must be
connected to the positive side of the electrical system and must
stop all electrical functions including magneto ignition. The off
position must be clearly indicated with the word “OFF.” If switch is
“push/pull” type, “push” must be the action for shutting off the
electrical system, “pull” to turn it on. Any rods or cables used to
activate the switch must be minimum 1/8-inch diameter. Plastic or
keyed switches prohibited. Switches and/or controls must be
located behind rear wheels on rear-engine dragsters.
2010 rulebook:
8:4 MASTER CUTOFF
