Drag Racing Tech
how to keep 60' time down??
Old Jan 14, 2013 | 08:29 AM
hotrodT/A's Avatar
Default how to keep 60' time down??
2000 trans am A4 long tubes true dual dumped with sweet thunder mufflers
P&p throttle body and torquer v2 cam tuned at mayhem. 375 rwhp. Im afraid when i go to the track its not gonna hook up so i wanna know if anyones got any advice for that?
Old Jan 14, 2013 | 09:30 AM
VandykeT/A's Avatar
What tires and torque converter?
Old Jan 14, 2013 | 10:09 AM
RamAir95TA's Avatar
What kind of suspension work do you have, if any? You left out far too much information for anyone to make any kind of educated guess.
Old Jan 14, 2013 | 10:44 AM
Slowhawk's Avatar
LS1Tech Sponsor
Tires is first.
Old Jan 14, 2013 | 11:26 AM
CamaroRacing12's Avatar
radials work wonders
Old Jan 14, 2013 | 11:49 AM
hotrodT/A's Avatar
Everything else is stock on the car and khumo tires. Nothin specail
Old Jan 14, 2013 | 12:54 PM
Camaro396's Avatar
I'm assuming by the low hp number it makes it's a big stalled auto car?
Old Jan 14, 2013 | 02:02 PM
hotrodT/A's Avatar
No stall
Old Jan 14, 2013 | 02:54 PM
VandykeT/A's Avatar
Without a stall and a torquer 2 its not gonna cut a killer 60ft if it dead hooks. Just load the torque converter and roll into throttle as needed.
Old Jan 14, 2013 | 06:39 PM
1BAD98LS1's Avatar
Throw a set of 26" ET streets on it and let her rip. With that HP your working with a drag radial wouldn't be necessary, just be added rotational mass.
Old Jan 14, 2013 | 08:06 PM
hotrodT/A's Avatar
What is the exact size for et streets for the stock rim? Could i do slicks on it maybe? Or would i have rubbing?
Old Jan 14, 2013 | 09:41 PM
1BAD98LS1's Avatar
26x10.50 i believe will work with stock.
Old Jan 14, 2013 | 11:08 PM
VandykeT/A's Avatar
26 x 10.5 fit fine but a et street is a drag radial unless you mean a bias ply which I wouldn't recommend. A radial is fine for a automatic car and they're alot easier to live with on the street. Not trying to be negative but a torque converter will make a world of difference in your car. Espescially at the track.
Old Jan 15, 2013 | 07:54 PM
hotrodT/A's Avatar
What kind of stall should i be looking at? Its a DD also
Old Jan 15, 2013 | 11:08 PM
VandykeT/A's Avatar
I would look for something in the 32- 3600 range, I'm not an auto guy so dig deeper but it will still be driveable. You still have the lock up for cruising. It'll just be a little rev happy mergeing in traffic and what not. Get a cooler and you'll be happy.
Old Jan 16, 2013 | 06:26 PM
1BAD98LS1's Avatar
I would have said "ET street drag radial" if that was what i meant. And Why wouldn't you recommend a bias ply?? I cut 1.45's with a bolt on car with them and thats after they sat outside for 3 years lol...
Old Jan 16, 2013 | 06:30 PM
1BAD98LS1's Avatar
If your going to put a stall in it you may as well put at least a 4k in it. I drove mine with a 4400 in it 70 miles round trip to work and back with absolutely no issues. Just put a good trans cooler on your car and it'll be fine.
Old Jan 16, 2013 | 10:40 PM
VandykeT/A's Avatar
I'm 100 percent a believer in a bias ply tire. Thats all I run but I have a stick car and need them. A radial doesn't give you all the lane walk and don't hydroplane near as bad if you hit water on the way to the track. Thats why I don't recommend a bias ply.
