Drag Racing Tech
stiff side wall slick or normal?
Old May 20, 2010 | 02:00 PM
StangEaterSS's Avatar
Default stiff side wall slick or normal?
I have been looking at the hoosier 28x10 and the 28x10.50 stiff side wall. thats the only 2 options in a 28 really. how do you determine what car would need a stiff sidewall? I assumed the weight of the car is a factor.
its a 2000 SS with a 6-speed manual trans and 3300 race weight.
Old May 20, 2010 | 02:09 PM
camscam02's Avatar
Stiff 100%
Old May 20, 2010 | 03:52 PM
AChotrod's Avatar
M6= STIFFWALL!! Lock thread please.
Old May 20, 2010 | 05:44 PM
Mikey 97Z M6's Avatar
^^^ Why does the thread need locked?
Yeah as mentioned, a stiff sidewall is usually for heavy cars or clutch cars that shock the tires.
Mike
Old May 20, 2010 | 07:05 PM
DMH Fabrication's Avatar
Stiff...these cars are heavy.
Old May 20, 2010 | 08:42 PM
fuel's Avatar
i had regular 10" slick and hated it.......go stiff wall
Old May 20, 2010 | 09:17 PM
z28racerlt1's Avatar
the main thing that I noticed between the two is that the normal tires actually show that they have alot of tread left but the side walls are toast. I would get about 35-40 passes out of them.
I have been running 29.5 x 10.5s MT for 2.5 seasons now. My 60' times have become WAY more consistant. Also I don't get fading out of the 60' times. They are good then no good. I like that better. I am now getting about 60-70 passes out of the tires. I definitely like that.
Hope it helps
Ken
Old May 21, 2010 | 07:12 AM
BlackScreaminMachine's Avatar
Internet Mechanic
PM JL-ws6, he knows his **** and will guide you good, All great points here but if he does not chime in, give him a shout out. I also vote for stiff btw.
Old May 21, 2010 | 05:43 PM
BADD SS's Avatar
what is your weight? Not every 6 speed needs a stiff sidewall. I dont run them but Im about 3100 lbs raceweight.
nevermind, just saw the weight im a tard....
Im not so sure you really need that stiff sidewall, im running 28x13.5-15 qtp's.. I think they are like the 28x10-15 regular slick. I think the suspension and setup will dictate better consistancy and et, rather than the stiff wall. Unless you were 3500+ lb raceweight.
Old May 21, 2010 | 07:01 PM
car is also street raced. so whatever works best on the street will also be considered.
Old May 21, 2010 | 11:02 PM
Bitemark46's Avatar
I spoke to the rep from M/T on YB and he said use a stiff sidewall for stick cars over 3000lbs. So you Fbody guys that are at 3400-3600 definately should use a stiff sidewall. My regular slicks have plenty of depth on the indicators but the sidewalls are trashed. So even at 3050 w/ driver I'm going to try a stiff sidewall.
-Mark
