Whats it take to run 7.5 or less in the 1/8th?
Ok so i posted track results a while back with my current setup (370 rwhp mustang dyno). Ran a 8.4 at 88 with a horrible 2.1 60ft. Went back with the et steeets and ran a 2.06 60'... dead hook at 1500 rpm's with stock stall = suck. Also stock stall plus 1-2 shift in the 1/8th mile = suck.
So I have right now ported ls6 heads. ls6 intake, tr220, longtubes, magnaflow.
Im changing to eps 226 234 cam and going to be ordering a 3600 circle d...
So do you think im gonna have enough gumption to hit mid 7's or what else should i be looking at installing. Would 3.73's be worth the time over 3.23's with the stall?
im hoping with the new stall i can get down to a 1.6 60' with the et streets(bias ply) and that should bring me down to a 7.7 7.8 but maybe a little extra power from the cam can get me the 7.5 id be happy with?? hoping!!
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Internet Mechanic
N/A cars need a N/A converter Bump the stall to 4400. 3.73's will help greatly as well. Cutting a good 60 foot is critical for 1/8th mile racing. Cut some weight out too. FYI your really pushing that 10 bolt's life and I suspect your going to be killing that very soon once your in the consistant 1.6's
1 Post
My 02 SS a4 is running 7.53 @90 w/ 1.63 60ft on Nitto 555r's.All that is done is LT,off road y-pipe,pully,P&P TB,Yank SS3600,LCA,PHB,Adjustable torque arm,no front swaybar,Weld Pro Stars 4''F & 10''R.No weight reduction and stock cat back,lid,3:23's.I would just do a stall for now and leave the cam for later.
Internet Mechanic
I think with the right stall and traction ,you should be damn close . I went from 8.5 in the 1/8 to 7.9 with my Yank ss4000 stall. Thats with a stock motor and manifolds . I would imagine it would bo even more on a car with a cam and headers . Dont know if the 373s ould help much . Maybe a tenth or so . I only gained .33 tenths in the 1/4 going from 273 to 373 .
For a simple gear change that's a pretty big gain IMO.
Had a friend that picked up 3mph going from the stock stall to a 3200. If the same holds for you I'd say you'd be right there cause your 60' is going to drop as well. Even going down to a 1.7 60' thats 4 tenths. Then add increase in mph with the stall. I'd say 7.50's are very possible.
-Mark
-Mark
What is the DA your running at? Seems like you should be able to get a much better 60' with those tires as I was running 8.2 on bald street tires with just full boltons.A stall should get you really close to that time with a better launch. Gears arent worth anything anymore unless your ordering something more than the 10 bolt.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
-Mark
-Mark
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
thanks for all the replies so far!
Before I deployed(just got back) I was running 7.3x's in decent weather with just a cam and 3600 stall, still on the 10 bolt. I was cutting 1.6x's everytime on the 10 bolt and 245/50/16 nitto 555R, which are a lot worst than M/T's. You will be able to get 7.5's easy with that cam and stall set up. By the way, I never busted my 10 bolt and was cutting 1.6's for over a year before I decided to upgrade the rear end because I added nitrous. Also that was stock 3:23 gears.
I gained no MPH from the stall, so far but I was running on the stock stall in great DA. Now in the heat and 1500 to 2500 DA. I am running 12.4 in the 1/4 and 7.8 to 7.9 in the 1/8. My stall shaved about 6 tenths off my 1/4 time.
With me in it the car weighs 3,740. My mods are in my sig, most of which are not a big help.
1 Post
I would atleast go w/ the LCA.M/T ET Streets work alot better then Nitto's.I have a cam & springs & LS-6 heads sitting around but i am scared of my car getting slower w/ them.Why mess w/ something when its working right.
1 Post
It was in Feb.@68deg.D/A i dont know.Weight do not know but only weight reduction is Pro Stars & no swaybar and i weigh 190lbs. In the heat it ran 12.0's 7 times in a row.
A little suspension, a good stall, a gear, and a lot of test and tune will put you where you want to be if not faster.
My times are in my sig. Livernois Stage 2 heads, fast 90, Futral custom nitrous cam, stock cubes, stock t/a, and and a stock 10 bolt with 4.10's cuttin 1.4x's a few hundred passes with no problems. And my fastest passes with the new suspension and gear was in july/august heat.
(Tore it apart nefore the good weather rolled around!!
lol)
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Appreciate the help from everyone so far. getting ready to order my stall and im thinking i may just go for the circle d 4c 3600-3800 rpm...If i can get some sub 7.5's im gonna be happy.
lol)
I run a Fast 90 intake with a PTM 90mm throttle body untouched straight out of the box, and as I said a custom grind cam Alan Futral told me that would work great on spray with my setup. 239/242 duration on a 114+4 LSA.
Mine can MPH sometimes really well (best of 99.0 on motor) but your 60' is where you can pick up your times more than anywhere. I ran those times on a 3,500 Fuddle nitrous converter foot braking it to 2000 and shifting it at 7000 and it still wanted to go higher. The right converter and suspension setup will REALLY improve your times. Just be prepared to make pass after pass writing down every detail and analyzing the info that you get to slowly make one small change at a time towards your final goal and your cars max potential.
awesome thanks bud, thats a nice setup you got there. Do you think the 226 234 cam is even worth it over the tr220 i have now? Or since im getting a stall should i just go BIGGER? Would it be worth it for the 1/8th? I already have the 1518 pac springs but could buy some good doubles.
