Drag Racing Tech
Battery Cutoff Switch
Old Jul 15, 2010 | 06:25 PM
Shownomercy's Avatar
Man-Crush Warning
Default Battery Cutoff Switch
Can it be this style?
If so, what amperage rating should I look for?
Old Jul 15, 2010 | 06:40 PM
AChotrod's Avatar
PM Fomula383 its his car
Old Jul 15, 2010 | 06:42 PM
StreetSilverado's Avatar
Yes you can run that style.
Old Jul 15, 2010 | 08:46 PM
kenSS's Avatar
yep that style or the push/pull style.
Old Jul 15, 2010 | 08:47 PM
slayer performance's Avatar
thought it had to be a push/pull? am i wrong?
Old Jul 15, 2010 | 08:51 PM
kenSS's Avatar
either one will work. As long as it shuts the car down when pushed or turned to off.
Old Jul 15, 2010 | 08:57 PM
you sir are correct.
here is what NHRA says
Any car with a relocated battery must be equipped with a master electrical cutoff, capable of stopping all electrical functions including ignition (must shut the engine off, as well as fuel pumps, etc.). The switch must be located on the rear of the vehicle, with the "off" position clearly marked. If the switch is of a "push / pull" type, then "push" must be the motion that shuts off the switch, and plastic or "keyed" typed switches are prohibited. Also, the battery must be completely sealed from the driver and/or driver compartment. This means a metal bulkhead must separate the trunk from the driver compartment, or the battery must be located in a sealed, metal box constructed of minimum .024 inch steel or .032 inch aluminum, or in an NHRA accepted plastic box. In cars with a conventional trunk, metal can simply be installed behind the rear seat and under the package tray to effectively seal the battery off from the driver. In a hatchback type vehicle the battery box is usually the easiest solution, since the alternative is to fabricate a bulkhead which seals to the hatch when closed. At present, Moroso is the only company which offers an NHRA accepted plastic battery box, part number 74050.
Old Jul 16, 2010 | 08:27 AM
94Z28rag's Avatar
Just to add to the post above, Summit now offers an approved plastic battery box as well.
