Drag Racing Tech
Trying to hook on the street...
Old Jul 31, 2010 | 10:33 PM
allbaugh_04's Avatar
Default Trying to hook on the street...
Mods-
230/230 .613 .598 111+3 "el torro"
LTs
LS6 intake
Cutout
Suspension-
UMI SFC
UMI Re-location Brackets
UMI LCAs non-adjustable
I have them set in the middle hole on the relocation bracket I believe.
Tires are 315/35/17 Nitto 555R 18psi
Gears are 2.73s
Transmission is built with fresh valve body and solenoids. No shift kit. SS4000.
I heated up the tires and tried going from about 1500rmps, spun punching it.
Tried 1500rpms again, eased into the throttle, hooked, then spun in the upper RPMS and chirped into 2nd.
Tried 3500rpms and eased into it, hooked, but kinda slow, not enough throttle I guess.
Not sure what else I can try, tires perhaps, but what....295/45/17 MTs?
Old Aug 1, 2010 | 12:22 AM
SS4Luck's Avatar
My 295 mickeys hook amazingly well @ 17 psi anywhere I am. On the street I come out around 3700 with some clutch slipping. They hook from 6K @ ghe track.
Only suspension I have is a torque arm and am cam only ms4
Old Aug 1, 2010 | 12:31 AM
daniel6718's Avatar
get rid of the nittos then try...if you really wanna hook on a meadocore surface you need a slick...
Old Aug 1, 2010 | 10:47 AM
Do you know your '60 ft with those? Do I even need 295 or I'd probably be better off with a small tire.
Old Aug 1, 2010 | 10:59 AM
projectX's Avatar
Wanna hook? MT ET Streets - You def will hook with these. I tried them, my friends have tried them. They are just perfect!
Old Aug 1, 2010 | 11:00 AM
projectX's Avatar
BTW My buddy launched his 400 hp Camaro at 4k and dead hooked! lol ridiculous
Old Aug 1, 2010 | 11:26 AM
Well what size of tire and model of the MT? Track or street?
Old Aug 1, 2010 | 01:32 PM
projectX's Avatar
Depends on your rims size. Ex. 16" rim would be a 26" tire. The ET Street's rock! There for street use but hook up like a damn slick!
projectX's Avatar
Jegs or summit has them.
Old Aug 1, 2010 | 06:11 PM
SmurfLSX's Avatar
I would goto a MT radial. On good pavement my nittos grab pretty good but on older asphalt I have to pedal it quite a bit....
Old Aug 1, 2010 | 06:36 PM
SS4Luck's Avatar
mid to low 1.5Xs with a best of 1.48 but i think the lights were off that night or something cuz everyone was faster and we had no idea why
Old Aug 1, 2010 | 07:00 PM
That's not bad, any suspension mods?
Old Aug 1, 2010 | 07:39 PM
custm2500's Avatar
Ph.D. in HUBRIS
Seemes like it has been pinned down but you need some real tires. The nittos help but are a real drag tire. The M/T or the like might spin a little bit but much better traction then the nittos for sure.
Old Aug 1, 2010 | 08:06 PM
krissoto's Avatar
Well the MT's are the best, but if your gonna keep the nitto's for now, try lowering the pressure, and doing a burnout with water, if it is possible. Roll out hard laying some rubber down, and then try to line yourself back up on it when you leave. Nitto's just don't seem to work all that well, for most.
Old Aug 1, 2010 | 08:54 PM
SS4Luck's Avatar
a tubular torque arm and 60K mile shocks and springs haha if i came out at 5500 it would hook and tehn unweight the rear. at 6K it hooked and just went like a ******* bat out of hell. by the time the nose came back down i was already into second and it didnt matter
Old Aug 1, 2010 | 09:23 PM
SSmoken's Avatar
definitely get some mickey t's. that will solve your problem.
Old Aug 1, 2010 | 09:26 PM
sidewayz28's Avatar
Mickey Thompson DRs
Old Aug 1, 2010 | 10:25 PM
What about my relocation bracket settings?
Old Aug 1, 2010 | 10:31 PM
SS4Luck's Avatar
What about the relocation bracket settings?
me?
stock... like literally, all i had was a torque arm and literally stock suspension
Old Aug 1, 2010 | 10:53 PM
No, I was just asking if I have mine set right.
