Drag Racing Tech
Who ACTUALLY does this???
Old Aug 14, 2010 | 07:31 PM
armyboyatc's Avatar
Well, drive 70 down to the starting line and then race! HAHA na, that sux man. Sounds like its time for a new clutch.
Old Aug 14, 2010 | 09:12 PM
Tally TransAm's Avatar
make sure your clutch and drivetrain are up to the task, if theres a weak spot limiter launches will find it
heres a vid of the only time ive been to the track on slicks and boost, 2step was set at 5500 making about 3psi on the line, next time gonna bump it to 6k and see if it hooks, should be fun. cutting mid to low 1.5 60's
MVI_2980.MOV
Old Aug 15, 2010 | 10:17 AM
armyboyatc's Avatar
I have a Mosier 9" 4.56 gears 33 spline axles, billet steel yoke, 3" chromoly DS rated at 2000 HP and a billet steel slip yoke for the tranny. I think I should be ok if my trans holds up.
Old Aug 15, 2010 | 12:14 PM
Mikey 97Z M6's Avatar
Originally Posted by Nitroused383
My issues is the POS self adjusting pressure plate the LS7 clutch uses. It obviously does not self adjust correctly all the time. If I set the cruise @ 70 mph on the freeway for about 60 miles it will adjust up correctly. As soon as I get off the freeway my clutch is firm and shifts great.
If you're in the market for a clutch, Monster Level III has held up really well for me. I got 80+ passes on mine without a single issue. A lot of those passes were hot laps when I was trying to dial in my suspension last year and not even a hint of slip, heat soak or clutch smell. No chatter during street drives either. Great clutch IMO. Stock master cylinder too.
Mike
Old Aug 15, 2010 | 12:52 PM
armyboyatc's Avatar
Mikey, You dont have any issues with that stock Master cyl?
Old Aug 15, 2010 | 01:07 PM
ghostbird's Avatar
here's another vid http://www.youtube.com/watch?v=mTSA778AqtA this is a bad *** car he launches on the rev limiter
Old Aug 15, 2010 | 02:45 PM
Nitroused383's Avatar
Here's how you get'r done. 26" tall drag radials, Mcleoud soft loc clutch is the way to go for a fast 6 speed. I don't think the Monster stage 3 clutch is rated high enough for what I'm doing
http://www.youtube.com/watch?v=FzLHN...eature=related
Old Aug 15, 2010 | 03:11 PM
armyboyatc's Avatar
Both those videos are SICK! I was reading in the manual transmission forum and Tick performance was telling some guy that if he had a drive line to hold it then launch it off the rev limiter on a stock trans.
Old Aug 15, 2010 | 03:16 PM
ghostbird's Avatar
i asked them on the phone when i bought my monster stage 4 and they told me the same thing that if i had a tough driveline that i could launch as hard as i wanted
Old Aug 15, 2010 | 03:19 PM
WSsick's Avatar
just to let you know OP, its Moser, not Mosier.
Old Aug 15, 2010 | 03:37 PM
armyboyatc's Avatar
Thanks for the grammatical correction! LOL
Old Aug 15, 2010 | 04:01 PM
  #32
WSsick's Avatar
Just thought I'd throw that out there. I know a guy who used to launch his SS off the limiter with slicks on a 10 bolt! scary but he never broke it.
Old Aug 15, 2010 | 04:02 PM
  #33
Nice!
I told them I wanted to put a 200 shot on my setup and Steve told me it wouldn't be a problem. They also got a twin disk clutch out now and I'm sure it would hold anything you could put to it. Not sure if it's adjustable or a "soft lok" type like the Mcleod....?
Mike
Old Aug 15, 2010 | 04:03 PM
  #34
None!
Mike
Old Aug 16, 2010 | 12:37 PM
  #35
HSESWS6's Avatar
Depending on track conditions I'll leave anywhere from 6200-7000 rpm off my 2-Step, my limiter is set to 7500.
Only vid I got since I'm at work, this was 6800
http://www.youtube.com/watch?v=0fSMfmiHhW0
Old Aug 16, 2010 | 03:07 PM
  #36
AChotrod's Avatar
Snapped my main shaft 1st 5k dump on a dead hook. Guess Im the unlucky one. I have a Street twin clutch, PST 3.5 alum DS and a Dana S60 rear. My trans is the weak point IMO.
Old Aug 19, 2010 | 03:57 PM
  #37
NSSANE02's Avatar
I don't leave off the limiter itself, but I leave off the 2-step @ 6200
Old Aug 20, 2010 | 08:49 PM
  #38
chrs1313's Avatar
Originally Posted by studderin
6800 before
6500-6600 is normal on dragwheels
the tick car dose 7300-7500 on a stock shortblok, LS1joe did too.
didn't they spin a bearing in that motor pretty fast...
Old Aug 20, 2010 | 11:20 PM
  #39
Gary Z's Avatar
I try to control my launch rpm by listening while I watch the tree. I aim at 6k, I occasionally hit 7.
Old Aug 21, 2010 | 06:53 PM
  #40
98blueSScamaro's Avatar
7k fast slipping the clutch with stock trans here. cutting low to mid 1.4x
