Motor Plate w/ Mounts
can someone post pictures of this torsional support? also how bad would it be to run a solid trans mount on the street? i only make low 4XX currently, but when everything is dont i will be making around 800whp.
suggestions on setting that one up?
Race your car!
Maybe the cars you've seen/touched/know/have owned had problems, but there's plenty of guys runnign NO torsional support and making pretty good steam, with no problems.
There are plenty of people that have not had issues with reluctor wheels breaking either. Doesn't mean it doesn't happen...
I haven't had the problem but I assure you I'm not stupid enough to think it can't.
The engine limiter, or as some are calling it a torsional bar, mounts from your frame to the engine in most cases. Keeping the drivetrain fom moving backwards. During hard acceleration while launching, the heavy engine and trans is trying to sit still while the rest of the car moves forward. This causes the motor plates to flex or break. The limiter will keep this from happening.
Many years back on my co-workers dragster, he broke two motor plates from not having a limiter on the car.
Using a solid trans mount on a street car would most likely never give you any trouble. The g forces from very hard acccelerations is what causes things to break. The lower the 60' times, the more possibilities there are of breaking. Hope this helps.
Running a motor plate and no midplate is a bad idea. Thats a lot of weight hanging off 2 points with a joint (motor to trans) in the middle.
With that said, a limiter is always needed to stop front to back movement.
And, according to my chassis shop solid trans mounts are great ways to crack cases
I think its a matter of what someone says and what they have had troubles with.The guy that builds my transmission said if I am going to run motor plates also use a solid trans mount because using a poly mount it then becomes the weak link.He uses motor plates with solid trans mounts on all his drag cars.
#32
It indeed ran 8.2 like you said. You obviously don't know what happened to that LSX as a result of no midplate and why one was added with the B/B chevy. The engine I purchased from Ken was a CLONE of the original with some of the parts that survived from the original. Your enough info is lacking as usual...
#34
Race your car!
Hahaha! I just realized what you said.
That had nothing to do with the lack of a mid plate. That was due to the block being one of the original lot that had a casting defect, that more then one person had an issue with...
The midplate was added with the big block becuase the thing damn near 1300 HP BEFORE any nitrous! That's a totally different power level that was in that car, that same engine/car have now gone 7.30 at some insane mph... that needs all the support it can get, and is a completely different animal.
Keep trying.....
#35
Would you be implying the cracked cylinders in #2 and #8? I saw the original block that was damaged, I was there when it happened, and saw the block 2 days later when it was out of the car on the engine stand when the damage was found....
Keep trying.....
Keep trying.....
#36
