Motor Plate w/ Mounts
JL when you say torsional support, what do you mean? I know this may sound stupid but ive been thining about ditching the solids MM and going to a plate system. Also as far as a solid tranny mount who sells then and how smart are they to have on a car that seems some (~2500 mi a year) street use.
Car is 90% track now with the other mainly being some street racing
The whole point of doing the mid plate is for strength, access to work on the engine or removal, and weight savings as the motor mounts are gone. IMO if you want a motor mount still in there. Just do a solid mount.
I have a motor plate in my car and a diagonal support that runs from the passenger's side motor mount to the frame rail.
I will be redoing that and putting a mid plate in, to help stiffen the entire setup up a little more...
http://www.madmanandcoracing.com/sho...aspx?itemid=16
http://www.madmanandcoracing.com/sho...aspx?itemid=15
When you're ready to order, give me a call. Our number is 225-673-3533. THANKS!
so according to that link; u weld the tabs on the frame and then bolt the plates to the tabs, right? will the LT1 plate install the same? do u have a pic of the LT1 motor plate?
