Anyone running a cam this big?
I talked to Cam Motion, gave them all the details of what my build is gonna be, and this is what they gave me specific to my setup. Vig 4K, 4.10's, Fresh Rebuilt 355 LT1, 1.5 RR, stock heads.
Is anyone running something similar Cam Only? Any potential problems I may have with something with these specs, i.e.; tuning, driveability, etc?
I posted this in the LT1 section but it's filled up with alot of internet mechanics nowadays, no help at all.
Another thought, do some research on what some stock eliminator guys are running for cams (if they'll spill the beans)...just as a broad comparison. Those are big duration, stock lift (or close to stock lift) cams on stock heads, etc.
I'm looking for real world results. Someone who has gone with a cam near this size/specs, and what their experience was.
Everyone in the LT1 section is all up on the AI/LE bandwagon, without even considering how something else may work.
this is the most amazing cam i have ever seen. these specs will revolutionize the way people design cams from now on. this is the end of the trail. there will never be a better cam. not in a million years.
happy?
you: hey what do u guys think of this cam for this purpose?
EVERYONE: looks like it will be hard to drive on the street
you: my car is my daily driver
everyone: oh, then u should go with something similar to the ai 226/234
you: no ur all wrong.
sound about right? all we are trying to do is help u with the question u asked. alot of people that responded have been doing this a very long time and have already been through this
I asked if anyone had a similar spec'd cam, not what you people with other cams thought about it.
Just stop ******* trolling man.
To add, I OFTEN do not see LT1 guys running that cam. This is not persay a LTx specific site. I would tend to wager Camaroz28.com was always MORE LTx Specific.
To me I always worry about PTV when running a cam like that. Any reason why your not running 1.6 ratio RR?? With the proper calc, the lift would go from the .525" to .560" which is not bad. Are the heads still stock, or untouched? Assuming if they are stock it makes sense, the heads get stalled out easy and all your doing is hammering the valve train but I figure thats the only question not asked.
240/250 600 lift 108 centerline.
Getting the intial tune down took some time, but after that, I could have drove it on the street, but it was a track only car.
4800 stall, 4.10 gear would idle fine and drive fine, never ran hot, had plenty of piston to valve clearance
I ran FAST Fuel Injection, but I would think you could get it to run on a stock pcm
You contribute nothing. If your after sound go ahead, If your after peak performance. Well id line up with you with my old hotcam setup anyday. And im not trying to be a dick on that. Just comparing it to something.
I think that if its sound, okay driver friendly and mid to bottom twelves your looking for you'd be happy.
