Drag Racing Tech
Today's weight reduction!!!
Old Oct 2, 2010 | 02:16 PM
  #41
SScam68's Avatar
Originally Posted by custm2500
I think you went little overboard with the fender lightining in those pics. Might want to step back and try to keep it looking like a car. Not many people look good driving a motor and subframe down the track.
Ditto, there is other stuff that will net you more without making it look like a race car.
I believe that reservoir is also for the horns.
Old Oct 2, 2010 | 02:21 PM
  #42
DTB_LS1's Avatar
The car still has fenders just no inner fenders guys. The car looks almost stock when going down the track.
Old Oct 2, 2010 | 02:37 PM
  #43
chrs1313's Avatar
i am going to tackle my inner fenders today too...wish me lots of weight removal
also dropping the lower rad support with horns was 18lbs and then add the 1.5lbs for the aluminum brackets...
so 16ish lbs saving,
if the horns are already gone take that off the total, i think they were like 3lbs each so you can have another 8.5lbs saving with alum brackets... if i did my math right haha
Old Oct 2, 2010 | 06:30 PM
  #44
DTB_LS1's Avatar
Hellz yeah, cut that bitch up!!! Btw I'm going to Byron again on Oct 30th and Nov 6th. I might take a look at my door bars before then too!
Old Oct 2, 2010 | 07:27 PM
  #45
camar0corey's Avatar
Door gutting is on my list this fall, plus whatever other metal I can cut from the interior. Have you seen those carbon fiber door panels? Wish I had $268 or whatever they are now for those.
Old Oct 2, 2010 | 11:36 PM
  #46
chrs1313's Avatar
you should have done it when you have the fenders off...I am doing mine here shortly...you should go to Cordova on the 6th there is a track rental...it is going to be a blast...
oh yeah 30lbs gone today
Old Oct 3, 2010 | 01:51 AM
  #47
studderin's Avatar
nice, were is this 30 pounds from
Old Oct 3, 2010 | 06:18 AM
  #48
DTB_LS1's Avatar
Yeah what he said. What else did you ditch to shave 30lbs?
Old Oct 3, 2010 | 10:22 AM
  #49
studderin's Avatar
any of you guys going to the shootout. bad ss, chris, dtb, thats other guy with the ls6 /speedinc cam in ill.
Old Oct 3, 2010 | 10:32 AM
  #50
chrs1313's Avatar
I am playing catch up to you guys...
14lbs airbag & bracket
6lbs air bag module/bracket/& e brake assmebly...I still need to pull the short run of cable, the rest has been gone for a while
10lbs for inner fender removal...
1lb ish for misc brackets not going back under the dash so far...
I want to pull all that sound deadening under there, the plastic mat under the carpet on the firewall...
I have pulled all my speakers since they run off amps that are taken out for track runs anyways... 10lbs
light weight battery will be another 18-19lbs...
so I am at 58lbs saving from my last run...add the door bars and I will be around 75lbs lighter...
and possibly pull the heat and modify the plastic so there is more room in the engine bay and drop a few lbs in the process...
Old Oct 4, 2010 | 01:02 PM
  #51
98blueSScamaro's Avatar
I am trying to see if i can make it. Me and chris Are going to the cartek track rental. Nov. with chris's car i will be towing his Ride out there with my Tbss. Next year we hppe to have both cars out there. and both well into the nine's. My car is all ripped up dash is out doing the a/c and heat mod's. And the inner fenders and alot more. Plus when i am out in N.J picking up my new setup. But i have also been pulling the dash on chris's car and modding the heater box as i did to mine to keep the heat but get rid of the a.c.
And darren slow down haha. Looks good man. I kinda want to find a short block to put my stock heads and my vindicator cam in to see if i can better my time after i pull the weight. my car was a heavy pig 3475 with me in it last year so lets see what i can get it down to.
Old Oct 4, 2010 | 01:12 PM
  #52
chrs1313's Avatar
^word...just think all this weight reduction will be gone after the 50-60lb bar goes in...aluminum is legal right?
we are both working on our featherweights...
Old Oct 4, 2010 | 01:37 PM
  #53
silversixx's Avatar
Remove the giant radiator catch can under your batter with this one. will shed off a few more lbs.
http://www.jegs.com/i/RCI/821/7040D/10002/-1
Old Oct 4, 2010 | 01:52 PM
  #54
DTB_LS1's Avatar
Yeah thats on my list also. The stock overflow is straight ugly and heavy.
Old Oct 4, 2010 | 01:58 PM
  #55
silversixx's Avatar
when I put in my lightweight battery I removed it, looks much cleaner
Old Oct 4, 2010 | 02:04 PM
  #56
silversixx's Avatar
You should also remove all the radiator support brackets and make your own maybe something like I did if that would work for ya.
http://www.fquick.com/images/vehicle...jpg?1273541177
Old Oct 4, 2010 | 04:41 PM
  #57
mike135531bubba's Avatar
how much does the stock overflow plastic catch can weigh? doesn't seem to be much, so what would you save, 2 lbs?
Old Oct 4, 2010 | 04:54 PM
  #58
Dirty Vegas's Avatar
I'm interested in the Cartek rental...
Old Oct 4, 2010 | 05:46 PM
  #59
this is all the way on the east coast you do know that right?
Old Oct 4, 2010 | 06:29 PM
  #60
airfix's Avatar
By the time you get a new catch can in I thik you'd be lucky to save 2lbs. I never weighed it or my new catch can so I can't say. I did more for looks than to drop weight.
