Spring Delimna - What would u do?
what would you do? I don't want to go to a rear coilover. Only other option I know is to heat the bottom coil w/ acetelyne torch and bend the coil out about 1/8", but don't want to ruin integrity of spring.
IMO you could grind on the inside of the spring. It takes meterial out but your not heating and cooling the spring and messing with the "temper"
This is my thought, but I'll let the experts chime in.
grinding does no good on the spring. this is some serious tempered steel. The springs already ate up two stones on my die grinder with no effect on the spring.
