How comfortable are drag racing seats?
If you really want a comfortable seat, these are the only way to go. I have one in my 69, it feels like a recliner.
http://www.redart.com/index.php?opti...d=44&Itemid=21
Sean
With no cruise and the door bar The 17wide is alot nicer for long drives so you have a little room to adjust how you sit slightly, you calf muscle ect. but thats not the seat. and you have room for a winter jaket, or 2-3 long sleeve shirts you notice the seat get sung like a 16 fit most guys, i would want that for a race car.
get the racecraft brackets and you can out them how you like.
I found a cheap way to mount just about any seat. You can disassemble the stock sliders. Take the slide and remove it you will be left with the bottom mounts. You can drill holes through them and bolt the seats to them using grade 8 hardware and spacers for the front. The mounts bolt in the stock postion and the seat is reclined back using the spacer. The stock bottom mounts are double thickness where you drill the holes.
