Drag Racing Tech
battery relocation(ive searched)
Old Oct 24, 2010 | 11:17 AM
trans2000am's Avatar
Default battery relocation(ive searched)
Ive read a ton up on this and just wanna ask a couple basic questions an go over what i have planned an just want to verify its correct. And im running all new wires NOT using any of the old stuff
1. alternator fuse- where is the best place to put it( closer to the alternator or closer to the battery?)
2. Im running all 2g wire is that fine?
3. what i have planned in my head on how to run the wires is
-2g wire from fuse boxes to starter
-2g wire from starter to 1 side of switch.
-2g wire from alternator to other side of switch(inline fuse somewhere)
-2g wire from battery to side of switch with alternator
grounds
- 2g wire from motor to frame rail
-2g wire from neg battery to ground somewhere in the back of car(whats the best spot?)
do i need any other grounds?
do i need a fuse inline with starter?
I also need to find a location for my on/off switch. any ideas?
thanks
Old Oct 24, 2010 | 06:32 PM
ttt..
Old Oct 24, 2010 | 07:57 PM
airfix's Avatar
Sounds like your on the right track. I'm using 1awg welding cable from my batt to my starter some people say it's overkill but seems to be working great for me. You wan't the fuse right after the alternator. If you search battery relocation or cutoff switch theres a ton of info, and pic's of where ppl mounted ther switch. Sounds like you've got everything figured out other then where your gonna put your switch.
Old Oct 24, 2010 | 08:23 PM
cool i just wanted to make sure before i go cutting the wire then find out i f*cked something up an have to buy it all over again... ya the switch is where im confused i dont really like the push/pull ones
Old Oct 24, 2010 | 08:28 PM
airfix's Avatar
I know of a few formula guys that have there turn style moroso cutoff switch mounted on the middle panel between the tail lights. It looks pretty good. I can't remeber there user names though. I'll do a quick search and see if I can find some pics for you.
Old Oct 24, 2010 | 08:40 PM
airfix's Avatar
Here's a link to a bunch of pics although there all push pull ones. I can't seem to find pics of the other style at the moment.
https://ls1tech.com/forums/drag-raci...ct-switch.html
Old Oct 24, 2010 | 10:14 PM
94Z28rag's Avatar
FYI push/pull is the only kind that are NHRA/IHRA legal.
Old Oct 25, 2010 | 04:54 AM
96LT1355Z28's Avatar
??? I have this switch on my car, it's never been questioned at any of the national events I've been to.
http://www.summitracing.com/parts/TAY-1032/
If it'a a push pull stye it must be "push off" and if it's a turn style it must be clearly marked which way is off.
Old Oct 25, 2010 | 01:50 PM
has anybody had issues with the on/off turn kill switch? like passing tech? i bought the complete relocation kit from burkhurt why would he sell me a kit that wont pass tech?
Old Oct 25, 2010 | 01:59 PM
airfix's Avatar
I've seen tons of cars at the track with turn style switches. Most actually have the turn style at the track I go too. And If its a push pull style it has to be push for off.
Old Oct 25, 2010 | 02:12 PM
camscam02's Avatar
Not true. It can be a switch as well. and either way they need to be labeled
