Drag Racing Tech
Traction issues....
Old Oct 27, 2010 | 05:33 PM
  #41
BLK02WS6's Avatar
Originally Posted by mad_steve
Yeah, we can only get our valving on the AFCO shocks. I understand wanting to keep everything the same on all 4 corners, but you might want the AFCO's on the rear, anyway. They have alot more in the way of adjustment. As you know, you have 12 clicks per **** on the Strange DA's, but with the AFCO's you have 42 clicks on the top and 24 clicks on the bottom.
And, just a bug for your ear, I can get you a discount if you buy all 4 shocks, with springs.
If you want a fast car, I would go with all 4 like he is suggesting and sell your old stuff off... you can't go cheap and go fast...
Old Oct 27, 2010 | 05:54 PM
  #42
AChotrod's Avatar
I didnt think Strange was considered cheap?????? I cant afford all 4 shocks but might go with the AFCO rears. Need to sell these tires/shocks asap! lol
Old Oct 27, 2010 | 07:16 PM
  #43
z28rob18's Avatar
too bad the comp shocks rnt worth much since they r inexpensive. this thread is makin me realize ima have to spent more money and change the rear shocks again. one day ill be callin madman for them afcos and the adj advice
Old Oct 27, 2010 | 07:31 PM
  #44
AChotrod's Avatar
Yeah a M6 is tuff and even worse when its a garage built car with no one to help. Everyone that calls Madman ends up flyin so thats my next step. Im also going threw them as soon as Im ready to buy a converter.
Old Oct 28, 2010 | 08:19 AM
  #45
mad_steve's Avatar
Give me a call when you're ready. I'm here all day from 7:30am until 5:30pm.
Old Oct 28, 2010 | 03:53 PM
  #46
AChotrod's Avatar
Sounds good! If this guy buys my old tires Ill be ordering asap.
Old Nov 1, 2010 | 02:12 PM
  #47
AChotrod's Avatar
Just ordered the AFCO rears from Madman. Thanks Steve looking forward to getting this thing working right & hope to be out this friday testing. Car also has the new Sportsman fronts rear MT drag radials mounted up and on the car.
Im selling my comp 3ways, ET fronts and Hotchkis lowering springs.
PM Me if interested.
Old Nov 1, 2010 | 03:58 PM
  #48
NHRA4MULA's Avatar
what gears are you running 355 ?? I have a m6 also thats not done yet so Im always looking for info ...
Old Nov 1, 2010 | 04:00 PM
  #49
AChotrod's Avatar
4.10s out back
Old Nov 1, 2010 | 04:38 PM
  #50
Broke EF's Avatar
Why are you selling the ET fronts?
Sean
P.S. Now that you have Afcos; you will need to spot us out... We still have the comp 3 ways out back with stock springs
Old Nov 1, 2010 | 05:02 PM
  #51
mad_steve's Avatar
Thanks for your order! Glad I could help. Just call me when you're ready for some baseline settings, and we'll have that beast hookin in wet grass.
Old Nov 1, 2010 | 08:17 PM
  #52
robsquikz28's Avatar
how much are the afcos? Get that damn car at the track already Mike. I want to see that car hook and book
Old Nov 1, 2010 | 09:29 PM
  #53
AChotrod's Avatar
Rob we should be at GLD friday. Come on up!
Shocks were 300 each and 40 for the mounting bracket. So all in all about 140 more expensive than the strange shocks....but I get MADMAN shock valving and tech
Broke Id need a football feild.........wait whos driving? lol, I wanted something better for the street. So I got heavier tires and that means the cancel out the shocks I just bought lol
Old Nov 1, 2010 | 10:17 PM
  #54
ZTwentyAteU's Avatar
Have you tried going up on tire pressure? Does the car hook initially, then unload and spin? I run 18-20lbs in my 28x10.5 S tires. rear shocks stiff to keep it from squatting so hard, and front shocks slow on the extension to keep from standing it up on the bumper. But i'm also on a auto, but transbraked, so it hits like a stick car
Old Nov 1, 2010 | 10:33 PM
  #55
223HAWK's Avatar
Thats my plans this winter..Mad Man AFCO rears!! Im a radial guy..I drive my car A LOT so radials are my choice. I dont like how a bias ply feels going down the track. I tryd ET Streets, I was faster on radials, I just never got them dialed in like I did with the radials. Im going this weekend for my last pass of the year to see if I can improve. Last time out was 95* out and ran 11.7s..added a drag bar and got A LOT more seat time..Now its 50* lets hope its a good weekend!!
Old Nov 1, 2010 | 10:51 PM
  #56
AChotrod's Avatar
Im hoping I can get the radials to work. This car went 11.6 at 119.44 with stock suspension and a 27" QTPs.
Since then I upgraded the cam, got a drag bar, Strange DA fronts, 28" QTPs, the comp rears, adj LCAs, adj PHB, relocation brackets and a 6point Wolfe bar and the car doesnt leave nearly as good. Next outing it will have the Madman AFCOs, 28" MT DRs and some MADMAN help on shock settings. Oh and a 150shot if the NA passes go good.
Old Nov 1, 2010 | 11:23 PM
  #57
BADHAWK51's Avatar
Mike, I would set the fronts on 2 and run the 12psi also try leaving at 5,500 and see what happens. The front end needs to come up and stay there and you won't be unloading the tire like that. I would be out there with you running if the trans didn't take a dump at the shootout. Also just curious are you running lowering springs out back ?
Old Nov 2, 2010 | 09:02 AM
  #58
Bitemark46's Avatar
Did you ever find out your strut travel?
Old Nov 2, 2010 | 10:59 AM
  #59
AChotrod's Avatar
The first vid was 14psi and spun out of the hole, the second vid was 12psi and the car bogged bad and had bad tire shake.
Damn that sux to hear about the trans but at least you WON!!!!!! Madman is going to give me some starting points for the shocks then tell me how to adjust them depending on what the car is doing, should work out pretty good!
I havent had much time with the car but plan on doing it when the rear shocks get here. Ill let ya know.
Old Nov 3, 2010 | 03:57 PM
  #60
AChotrod's Avatar
Sweet! Shocks showed up today but looks like the brackets will be here tomorrow(assuming the 2nd package from Ca is the brackets). Cant wait to get home and check them out then get them on the car.
