Chained down
Nothing like going 177mph with a broken tranny case (2 bolts holding it in)
I think the reason this motor is has such a small window right now is because the converter is still 1,000 rpm or more to loose. When we can get one tight enough I think it will widen our susp. window and tighten the nitrous tuning window up a little.
Good luck to you guys ... Some of the 275 guys make it look easy, it aint !!
Thanks to MADMAN for his help !!
your right a tighter converter will help you control the power more instead of it flipping the HP on like a switch....
the motor plates and mid plate will end up helping the longevity and probably help you put a little more torque to the tire... Febuary is giong to be interresting for x275. there are several people who i think have a good chance at winning, you included.
