Rear spring for drag racing?
Going with QA1 single adjustables in front with 300 or 325 lb spring, and Double adjustables in the rear. Just not sure what spring I want to run.
Any help is appreciated.
Thanks-
Zach
Zach
To use these spring you will either have to modify your stock spring location or do a coilover set-up.
I weld a adjustable seat to the rear-end and modified the upper by welding a 3" diameter piece of pipe to hold the spring in place.
Bob
