Cutting the radiator support?
also where would be a good place to hook into the motor at to hook it up to a cherry picker?
**** i hate this car sometimes
Best attatchment point, aside from using a Motor plate for the valley cover is the front and back of the cyl head. You would go diagnol, ex. Chain starts @ Front Passanger head, and finishes at Rear Driver Side Cyl. Head.
Im not against taking it out the bottom, but my old man is hesitant so if i can do it out the top id rather keep him happy being that he gave me the load to fix the motor (trex here i come
) Trending Topics
Also, I had to pull the front bumper to get the picker in far enough when I installed the new engine. As you can see in the picture below, I left it in place for removal and had plenty of room.
I made one this way, and it works like a charm. Stock radiator support, the motor will come out NO problem, just pull the intake, and you have all the room you need.
If you really want to make it easy, get it up in the air and pull the oil pan, then it really comes out easy from the top.
I will never, and I repeat NEVER pull a motor out the bottom of a 4th gen f body. I'm 110% that I can get one out the top easier then I can thru the bottom, and when I'm done, there's no rebleeding brake lines, realigning the car cause the k member was off, etc.
If you want to take the radiator support out, and make it removable, you will have the ability to take the motor and trans out as one piece, almost as easy as it is to take the motor out alone. If you have the cowl notched back, that makes it really easy as well. Hood removal, I don't do... I just unhook the shocks and lay it as far back as it will go, and pad it with a towel, and tie it back with a rope... works perfect, and then you don't have to mess with aligning the hood either.
the 3 minutes to reblead the brakes is nothing, and it doesnt need an alignment, it has pins it aligns with that wont allow it to bolt up but in one spot
Have fun with that car that you can't move with no K member in it too. Unless you enjoy putting stuff back so you can roll the car around if needed then take it back apart so you can reassemble.
The guys on here that are telling you to take out the top, probably have done it more then once, and chances are, they are in the know with how long it takes to get a motor built, etc.
The 3/4 inch threaded rod got a slight bend, but that was it. I would shake it around every time I went out in the garage too... no problems.
I did put a small steel sleeve spacer in the middle of the hole, and a bolt on both sides, then a couple bolts and large washers in the middle to hold the hook where I want, and to act as a load leveling system.
Works perfect. I know an lsx motor complete is about 525 lbs. I had WAY over that hanging on this thing for a good amount of time, no problems. I was concerned about the plate cracking.. but the alum seems pretty thick, and tough. I wouldn't want to leave something on there like an important engine, but to pull one, get it out of the car, reinstall, and move to an engine stand and whatnot... absolutely no worries.
I made this, becuase I couldn't get a QTP lifting plate when I was looking for one. I called everyone that distributes their stuff that I could find, including getting in touch with Barry on here... noone had one. So... shade-tree engineering had to come into play LOL.
