Stupid Driveshaft ?
Stupid Driveshaft ?
How hard should it be to slide the drive shaft in/out of the transmission(six speed)? I have to knock mine out with a dead hammer. I was wondering if this could be causing my susp. to bind up. I also had to have the seal on the back of the slip yolk replaced because it went missing.
Internet Mechanic
When I first installed my Moser and 3" Denny's Nitrous Ready Steel DS. I noticed the first time it was binding but everything was newly installed. I recently took it out to put a D/S Loop ( redundant!? ) in and it came out VERY easy.
If you do not have this situation, then it could be twisted either on the output or DS input shaft.
As long as the manuals are like the autos then there is a spacific way it goes in If belive.
If the trany yoke isn't indexed then something is wrong. It should slide in and out with very little resistance.
LS1Tech Premium Sponsor
we have seen a few twisted yokes in the last few years and it seems the higher powered M6 cars on slicks are prone for this, especially if you have a good clutch. there are a few different 1350 series trans yokes available so just a upgrade yoke will do the job for ya. call us and we'll give ya the hook up on what you need.
Moser, you say. did it look like this one? billet with the bolt on caps...
http://i2.photobucket.com/albums/y11...n/IMG_5076.jpg
I just changed to if form a $25 spicer that had been find.
http://i2.photobucket.com/albums/y11...n/IMG_5020.jpg
http://i2.photobucket.com/albums/y11...n/IMG_5018.jpg
