Strange Lighweight front Drag Brakes
Burkhart makes a kit with a chromoly spindle and a 3rd gen drag brake assembly for a little more than 4th gen drag brakes. The kit is $1075 with Aerospace brakes or $1200 with Strange brakes. I'm sure you'd save an honest 20lbs more with this kit. The stock spindles are heavy as hell. Last time I checked 4th gen drag brakes were $980ish which is a joke. Here's the link for the Burkhart kit:
http://burkhartchassis.com/id84.html
Race your car!
I had aerospace with the stock spindles, which worked well and saved a GOOD bit of weight (I had the hub style, which have their own hub), and now have the complete burkhart front end... I can tell you that you are going to save about 30 lbs more with the LW spindles then you would reusing the stock ones....
And for the price of the burkhart kit... why would you not?!?! Due to it using the 3rd gen brake, the kit price is only 300 bucks more... for another 30 lbs off the car, on the front... that's a no brainer!
Race your car!
I went from a stock k member, stock a arms, stock rack, a set of qa1 shocks and the aerospace brake kit to the full burkhart front end with afco double adjustable shocks, and it was 130 lbs lighter then what was on the car. I also had mine built to narrow the front end 1 inch per side as well.
LS1TECH Sponsor
Thanks for all the compliments. The lightweight spindles use a different brake setup than stock. If you want to do that, then do it now and don't spend $$ on brakes twice.
LS1Tech Premium Sponsor
We offer a Strange brake setup for the 98-02 stock spindles that does not require any cutting of the control arm or spindle. this is also upgradable to the race spindles at a later date without throwing away expensive parts. comes with all hardware, brackets, and even braided lines and adapter fittings, and best yet it's much less costly than the regular kit. fwiw you get most of your weight savings from the brakes alone, but if you get the spindle at the same time that's the ultimate. we are also working on the same kit for the 93-97 spindles.
EDIT-- For Mr Burger--what is your opinion on the difference between the Aerospace brakes and the Strange brakes? Are they worth the $125 more? I don't know anyone personally that runs either so any feedback is appreciated.
Race your car!
![Bulls#!t](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bs.gif)
And considering that they're within a lb of strange, at over 150 bucks a set cheaper, I'll run them and feel pretty good about it. Stopping power, was always good IMO, I've driven cars with both, and I can say that neither one feels any different as far as braking power.
LS1TECH Sponsor
The Aerospace brakes are within ounces of the Strange. I would say the weight is essentially the same. As for quality, we have sold thousands of sets of Aerospace and a lot of Strange. Never had a set of Aerospace come back for anything. We have not seen the sticking of the piston as has been rumored either.
The quality is about the same with either. You just pay a bit for the Strange name. If you want the designer brakes we can sell you those. If you want great brakes at a great price we have those too.
Race your car!
The only thing I wish aerospace would come out with.. is a carbon fiber rotor, that could be bolted up in place of the steel ones...
Steve, any chance that's a possibility? Maybe they're working on something, and it will be an easy swap for guys like me that already have the brakes... I could just buy the replacement carbon rotor and pads to go with it... that would be mint.
