Drag Racing Tech
torque arm relocation crossmember problems
Old Jan 28, 2011 | 11:08 AM
duckvader's Avatar
Default torque arm relocation crossmember problems
i am looking at torque arm relocation crossmember. is their any more vibration when driven on street ,highway. does it stop some rear trans lift , headers etc hitting bottom of car. is it worth the cost. i have read about some trans tail shafts cracking.
Old Jan 28, 2011 | 12:07 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Let me put it my personal exp.
I have a M6 Car that I race and I race it hard. Like 5k Clutch dumping is the way of life of racing this heavy car.
Long story short was out of concern of trying to be fast and not breaking parts, one of my intended purchases was a TQ Relocation cross member.
I use BMR and UMI and I did settle on the UMI due to cost. IMO the BMR unit has a better way of adjusting after the unit is installed. In most cases it is best to have a helper and a lift to see if Aftermarket Y Pipes interfere. My Dynatech SuperMaxx kit did with the UMI unit and I had to grind, luckily I did not lose the holes I needed to keep.
As for the rest, at the time I did do a Poly Trans Mount w/ preload plate and above 75mph there is a vibration. i still have stock engine mounts.
The ONLY time I have seen stuff crack is either it bound in the driveline upon launch or a SOLID trans mount is being used and the launch being so violent. Mostly that comes from the UNI-body not be sufficently tied together. IF anything that goofey set up running off the trans is a God send and knowing how the car will re act and another moveable piece fixed to the chassis is a good thing.
By using a trans mount thats better then stock rubber will help avoid deflection upon accelration, but more maybe needed if a particular car is having bad twisting issues.
IMO the vibrations re worth it, knowing that the driveline is more solid.
Old Jan 28, 2011 | 12:31 PM
slow67's Avatar
Gingervitis Addict
When I did a 4L80E I was forced to use a relocated torque arm. I chose the Yank cross member. I have no additional vibrations from it (poly torque arm bushing on a stock torque arm).
Old Jan 28, 2011 | 01:41 PM
duckvader's Avatar
i think when i get on car , the trans is lifting with help from torque arm, and my headers are just touching floor..yank has a good price on their's but they do not make them for 93-97. i also had a poly trans mount and i couldn't stop it from vibrating, went back to stock ,no vibration. i do have poly engine mounts. i saw some pictures and i also was wondering about exhaust clearence. they are sure close to y pipe. i have pacesetter long tubes and y pipe . anyone else have clearance problems
Old Jan 28, 2011 | 02:26 PM
camaroz28lt1at's Avatar
Pacesetter longtubes and y pipe are known for hitting on the drivers side. I used to have them with all poly mounts and they still hit. I now have Kooks longtubes and y pipe and have zero problems. I have the UMI torque arm relocation crossmember and no vibrations here.
Old Jan 28, 2011 | 02:37 PM
jmm98LS1's Avatar
UMI relo cross member here, poly motor & trans mounts and I don't notice any vibrations.....but my car is pretty fuggin loud too.
Old Jan 28, 2011 | 03:12 PM
duckvader's Avatar
do you mean pacesetters headers hitting drivers side floor ,or relocation bracket. did you have pacesetters when you had umi relo crossmember installed. what i'm trying to find out does relocation crossmember help with the headers hitting floor,broken trans mounts by taking some lift off trans. also guys with m6s should notice the shift not lifting so much.
Old Jan 28, 2011 | 04:19 PM
Crossmember had nothing to do with longtubes hitting. Same with stock or umi.
Old Jan 28, 2011 | 05:34 PM
MrElectric03's Avatar
I used a BMR relocation for quite a while and had no issues. Ive seen stock tailshaft housings break off and it sucks.
Old Jan 29, 2011 | 08:43 AM
JL ws-6's Avatar
Race your car!
I ran the BMR relocation bracket, and it fits perfect, no cutting needed even when I had the QTP y pipe on, which is one of the biggest/most pipe type that's out there (not a bad thing, just the way it's set up to utilize a good merge collector)
I do NOT like the way BS had to cut yours to make it clear... those 2 holes you don't have anymore might have been needed someday down the road, and now you don't have them, unless you redrill the entire thing, etc. Plus with no slot on the top it's a BITCH to try to adjust the tq arm position, doing that at the track on your back, is NOT happening like I could with my BMR piece... which was really great when getting the car set up.
The madman type arm is still the best deal with the slider on the front, the height adjustment holes on the crossmember and on the rear end bracket, I'd really like to see him make a crossmember for a glide/TH350/400, and a longer version of his arm, with the same adjustments on the front and back that his current design has. Build a good DS loop into the arm, and one on the back of the tq arm, and you'd have a killer piece with the needed safety built right in
Brian...... ever done one like this, did it work better, worse, any reason not to do it?
