Proud to introduce our new F-body fuel cells!
![](http://i53.tinypic.com/23ubxog.jpg)
![](http://i56.tinypic.com/xlf028.jpg)
![](http://i56.tinypic.com/2lopbb.jpg)
We are happy to introduce our trunk mounted aluminum fuel cell. It is made for a direct fit in the t-top well of 4th gen f-bodies (t-top racks must be removed). It holds 14.86 gallons, and is sumped with dual -8an output. It also features a single -8an return and a -8an vent. You will have to cut a small section of the t-top well out to accommodate the sump. The fuel cell also features 4 threaded mounting feet for an easy bolt in installation.
We take pride in our manufacturing, and these tanks have some of the nicest tig welds you have ever seen.
Pricing is going to run 359$ each. There is a around a 2 week build time as these are build to order.
PM me for details or ordering.
The sump does have a baffle plate over it on the inside with 5 1.5" holes through it.
This is not a generic fuel cell, its made specifically for this application.
Installed pics coming very soon
By the looks of it, I am assuming in order to get 15 gallons, that cell must stick up and out of the t-top well right? Obviously you would need a bulkhead, but Im just trying to get a feel for how tall it is...
We wanted to give the most volume possible while freeing up room under the car for the more universal coilovers / antiroll bar setups. Most people already have the battery mounted in the spare tire well.
Don't like the weight of 15 gallons? Dont fill it up all the way
Atleast this way you aren't limited to the smaller volume.
The final weight is 18 lbs
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
