Driveshaft RPM
Driveshaft RPM
Just wondering if what setups people have for logging Driveshaft RPM to see what the converter/transmission are doing? I know BS3, FAST, etc. have these sensors...but what are people using that still utilize the factory computer? Would just be nice to see what the transmission is doing going down the track.
Racepack as far as I knew, didnt know about the others. Subscribing, I wanna know more about this, all the really fast cars I have seen log this to optimize the traction tune (bringing in boost or Nitrous). Another thing I just found out this past weekend @ SGMP (Redemption II) is that they are also using G-meters, never would have guessed that myself.
Hopefully we will have some people chime in here.
I have racepak syste which is sport man it has the g meter and drive shaft sensor and volt and rpm .. So after the run you can go back and do your reading and the good part with it you can add any sensor in the fetcher if you want And you can log them with the racepak soft wear . And it's so easy to install .
Race your car!
Autometer has a tach that has the output for both driveshaft and crank RPM, that way after a run you can go back and look at it, if you want to do something and not change PCM's or go with a race pack dash type setup...
I think they're about 600 bucks, alot of $ for a tach I know, but it's alot cheaper then most of the other options.
DriveShaftRPM = MPH*1056*RearGearRatio/(TireDiameter*Pi)
Notes: Pi = 3.14159, TireDiameter (inches), The factor 1056 converts miles/hour to inches/minute
You can record Vss (MPH) and Engine RPM using HPTuners Scanner and export the log to Microsoft Excel
Then using the above formula, calcluate:
TorqueConverterSlip = EngineRPM - TransRatio*DriveShaftRPM
Excel is an easy way to do these calculations and display the results graphically.
