Help: 550hp on 28x10.5-15 Et drag
#41
Spoke with Jon from texas speed and gave him a full rundown of my setup and specs and he recommended me with one of their custom cams the specs are:
250/260, .621/.625, 113 LSA 110 ICL, 1.7 Rocker Ratio
was told it should work very well NA and on the bottle
#43
My susp is nothing special. b.m.r tq arm,lca's w/relocat,b.m.r rear drag sway and hals all the way around. I set #2 front and #6 rear driver #7 rear pass. I have stock springs all around. pin angel is -2. on the 26'' tire i hook better then most i see at the track. the only one who does out hook me is a much faster on big tires.
i started gettin this when i went to m&h tires.
#44
JL howabout something like this then? 248/254 .615/.595 112+4 , Got those specs from Vengeance, was told that should work extremely well NA and can support up to a 200shot, I'm waitin to hear back from Texas Speed and Vengeance and I'll probably go with one of the two... Might also be converting a th400 sooner than expected so I dont plan on driving the car on the street anymore so i definatly want something agressive
#48
wow this thread is ALL OVER THE PLACE but ill be damned, JL stuck thru it and got that info out there for all the masses!
z28kid, every other post has something different stated about your setup...how can we/JL help you if you are giving different info on ur setup all the time? You say you had qa1;s all around and acted like u knew about settings, and then you said u only had them on the rear, fronts are blown, then you said you had stock front and rear and all qa1s were blown, THEN you said you tried the rears and they were leaking and you had no idea how to set them up and what the numbers meant. ALSO, you said you had brand new tires and thats why you were doing a long burnout at first and now ur saying you have bald nittos on the car....which is it?
Im not trying to be a dick, dont take it that it way, we are here to help and JL has provided a **** load of info, which is great but if you want logical, HELPFUL, accurate answers, we need the same type of info about the setup.
Good luck getting her dialed in. That front is waaay too high, I dont lilke how it sits. Hopefully getting some new shocks/springs in there and a good alignment will level her out. That alone can make a big difference on your wheel hop and spinning issues.
#49
#53
got into a fender bender on the street....since then I have decided to only track the car. Rebuilt the QA1s all around, added a fiberglass hood, kirkey seat, and interior is fully gutted along with a lightweight steering column,fiberglass dash,lightweight steering wheel on the way. Alot of weight has been taken out from the car since then. Also going with a custom grind cam from Pat G in the 24x/25x duration....havent ran the car this season yet though
#54
